Problem with lt1 1997
Old Sep 22, 2010 | 05:53 PM
RS91LT1's Avatar
Smile Problem with lt1 1997
GREETINGS, I HAVE A COMPUTER WITH AN RPOBLEMA A LT1 1997,,, NOT TO SEND CRANCK CURRENT SENSOR, AND NO SPARK TO SEND CURRENT AND THE CABLE TO BE FOR THE SENSOR CRANCK NOT SEND THE 5 VOLTS TO DEVE Command ( NO MARK NADA),,, IT IS NOT,,, COULD DESIR ME IF YOUR COMPUTER OR ELSE IF,,, OR HOW TO TELL IF YOUR COMPUTER IS BAD,,
THANK YOU
Old Sep 22, 2010 | 06:02 PM
ryanisfast's Avatar
Hey man, you might be able to get help if you write out what your problem is more clearly.
Old Sep 22, 2010 | 06:04 PM
Cam95Maro's Avatar
Wow yeah idk what that means sorry
Old Sep 22, 2010 | 06:41 PM
alexcoreas's Avatar
HuH what are you saying. I don't listen to hip hop
Old Sep 22, 2010 | 06:48 PM
jaycenk's Avatar
Owo!!! Folly hucking mell.
Old Sep 22, 2010 | 09:43 PM
defaultexistence's Avatar
Thread Fail.....
Old Sep 22, 2010 | 09:52 PM
TrippyJoey's Avatar
I'm fluent in english, spanish, some german, and some french. Yet I don't understand what he is trying to say.
Old Sep 22, 2010 | 09:56 PM
Paul Bell's Avatar
That's MISTER MODERATOR
RS91LT1, welcome to the LS1Tech forums.
First, TURNOFF YOUR CAPS LOCK BECAUSE IT LOOKS LIKE YOU'RE YELLING AT EVERYBODY.
Second, go to your profile and make a basic signature that says what your car is and what you have in it.
Third, try to be a little clearer and better describe your problem. What is the car doing or not doing? Did it start acting up after you did something to it?
Fourth, it's hard to understand a messed up single long run-on sentence like what you wrote here. Make it easier to read.
We'll all try to help you out....
Old Sep 22, 2010 | 10:39 PM
great421's Avatar
I think I understand; (if I can translate his text-speak; I've got a 16 YO son) -
His car has a no-start / no spark condition.
He also has a crankshaft position sensor code.
He wants to know what to check and how to check it to determine if the crankshaft position sensor, wiring harness, or the PCM is the root cause of his car's problem.
I would say check the fuse which powers the sensor first, and if that's not the issue, then replace the sensor, but that's just me... I can't see his car to determine if his wiring harness is the issue or not, and the PCM is the last item replaced in all GM diagnostic trouble trees.
Old Sep 22, 2010 | 10:53 PM
tricked94camaro's Avatar
seems like somebody is using a translation website to go from spanish to english
