Need cam only numbers
Ran 13.7 stock cam 3000' DA
Cam,rockers and tune 3800' DA car ran 12.97
This was a friends car w/ 160k on it
http://www.youtube.com/watch?v=N3xrMN4poVw
1.NO weight reduction
2.Stock suspension
3.18x9.5 up front
4.Sway-bar still intact
5.Yeah DA and in the desert
You guys are funny with ETs,someone will post a time and you go for the juggler. I even listed the DA.
Car is on par since 3800-4500' DA is roughly 8tenths to a full second so thats hi 11s at sea-level
AINT RUNNIN 11s here bro sorry!
Fastest cam only Lt1 here in vegas ran 12.4(comp 227/233)
2.Stock suspension
3.18x9.5 up front
https://ls1tech.com/forums/lt1-lt4-m...o-archive.html
Guess the sig wasn't obvious enough. I hope it is now.
http://ltxtech.com/forums/showthread...ay-at-the-dyno.
I would say so, its called heat index coming off the track....
Maybe you should bring your beast out to the desert, you would be depressed when you get your time slip!
It must factor in somewhere, you seem to like to argue points just to attempt to make yourself known. Like i stated bring your 396 on out here and see it go slower than it does now.
My car for instance is a bolt on car m6 had 4.10s and full weight. my avg is 13.2@106 same set ups at sea-level w/ DA 500 to negative generally run 12.4 or a tad quicker..
