What valve spring should i get?
I will be running:
-Comp Cams Pro Magnum NSA 1.6RR's with a 7/16" stud (guide plates, harden pushrod ect..)
-Stock Cam
Future plan will be Ai 230 / 238, will i end up having to buy springs twice?
I have 1.6rr's with a CC503 grind.
On another note, whats max lift on stock cam with 1.6RR?
Is some of the springs mentioned in this thread too much pressure for stock cam?
comes with everything youd need. except a valve spring compressor. you can get a "tims tool" or for $100 you can get the crane setup that is also sold at byunspeed.
i dont think youll have any such problems running those springs with a stock cam.
Stock heads? No point in going over .600 total lift. Of course somebody is going to argue with me.
Far as stiff springs on a stock cam, it would probably handle it better than the cast cams a lot of guys swap in.
