Posi trac? worth it?
Also depends on driving habits.
And you already got posi trac, son! (for some reason this reminded me of joe dirt?
You can use your same gears, but you need to buy the correct series carrier (posi unit). If you have lower than 323 you have a 2 series, 323 and higher you have a 3 series. If you are going to replace the posi you should upgrade the gears while you are in there, they won't charge you any extra to do it. 373's will give you a real nice gain without sacrificing too much top end. So if you decide to buy 373 gears, you will want to buy a 3 series carrier to fit them.
