Seafoaming a 17 year old car, good idea?
Old 11-27-2010, 02:27 AM
SexyTransAm's Avatar
i did my car when it was just under 100k ( 1 can in gas, 1/2 can in oil, and 1/2 can in break booster hose to intake.) when i was done and changed the oil after 100 miles i could tell the car ran better and when i would rev it, it moved faster into the rpm.
Old 11-27-2010, 08:52 AM
nascarnate326's Avatar
Thats the same experience I had.
I did 2/3 can in gas tank and the other 1/3 in the brake booster. Let it sit for 20 min and start it up and beat the **** out of it. My idle was much better.
Old 12-31-2010, 07:06 PM
AmirGTR's Avatar
People say the spark plugs will be fine if they're not too old. Seafoam only takes out spark plugs already on the verge of going out...true?
Otherwise I can put my old plugs back in, run it, then put my new ones back after I'm done.
Old 12-31-2010, 10:29 PM
Village Troll
SS RRR's Avatar
This post is over two months old and you're still on the fence about doing this?
I guarandamntee you if you were smart enough to change your oil faithfully and ran the car to operating temperature most every time it was started seafoaming it won't make any difference whatsoever.
Old 01-05-2011, 02:58 AM
AmirGTR's Avatar
Yeah I had finals and been on a business trip for the past month and I changed my oil 2k ago, so cut me some slack and go make yourself look a douche in someone else's thread.
Old 01-05-2011, 06:19 AM
Village Troll
SS RRR's Avatar
I just saved you thirtysomething dollars and this is how you are going to type to me? The nerve!
Old 01-05-2011, 07:30 AM
quik95lt1's Avatar
IMO the only reason to put seafoam into the cylinders is if there is a carbon knock. If the a valve cover is popped and the engine is gunked up, no amount of Seafoam will clean it to any acceptable level. Don't see any reason to put it in the tank either.
Originally Posted by 01ssreda4
Don't do it. Seafoam is the devil.
Originally Posted by Young camaro
Seafoam is bad news IMO... don't fix it if it ain't broke
YEP, YEP, and YEP..........I dont like it!!!!
Old 01-05-2011, 08:02 AM
gregrob's Avatar
No idea how this band wagon got started, but as already mentioned it is throwing money away in an engine that has been properly maintained, and it has the potential to do more harm than good.
Auto rx is the only product I would use, its not a miracle cure rocket fuel, but it does have more merit than sea foam imo.
Old 01-08-2011, 01:22 AM
AmirGTR's Avatar
Look the only reason I'd ever want to do that is because lt1pcmtuning.com strongly suggests it. I'm fixing it because it IS broke. I just failed smog. I'm not asking if you like it or not, I'm asking if I should do it or not.
Now if anyone knows if I need seafoaming before getting a tune, leave me a line. That's all I wanna know at this point.
Old 01-08-2011, 07:54 AM
ThreeHonks's Avatar
I dont think it will really hurt it but dont go overboard. Maybe like 2/3 can in gas tank and only the 1/3 can into the brake booster hose.
Old 01-08-2011, 08:51 AM
camcamaro1991's Avatar
Post Seafoam
Seafoam/decarbon liquids DO NOT work period!!!
Please use some common sense here, and lets start with the basics first!
The correct process is to be finely mist the cleaning agent in front of the throttle blade/s but behind the MAF to follow the the path of the air flow using a controlled device.
Using the brake booster hose to suck fluid into the back of the intake (against airflow) is a complete joke and the agent will never make it to the front cylinders. (Whoever stated to use this method, I would never even let him touch my lawn mower, and for those would used this method stop working on vehicles)
Have you ever seen a engine before and after using seafoam or any other carbon cleaning product? I have, because I have worked on Mercedes-Benz for years. Client car comes in for a check engine light, misfire codes from the physical error with the cylinder head (tech removed cylinder head exposing the valves, pistons, etc this is where you can actually see the carbon beyond any resonable doubt.), carbon build up is everywhere!!! intake, valves, pistons. The tech fixs the error, the service advisor recommends and then sales a fuel injector and decarbon service to the customer.
tech performs the fuel injector & decarbon sevice, lets the vehicle idle and runs it through some 4000 rpms for about 30-45 secs to help burn off any exessive left over, (but this time the tech skips following the correct process for burn off & evaporation, the liquids puddle in the back of the intake) tech gets out of on the road and hammers the the vehicle to get rid of any build up in the cats, KA-BOOM!!! the puddled decarbon cleaner agent was still in a liquid form, cracked the piston, destroyed the cylinder. Ive seen 3 other techs make sloppy mistakes and try to rush a job.
Tech took the engine apart to examine the carnage, guess what the other remaining cylinders still have the carbon everywhere!!! the only difference the intake is a little cleaner but still has carbon, the valves and pistons the same carbon everywhere!!! Again I have seen this 3 other times,
The smoke is a chemical process of burning off the toxic decarbon cleaning agent. not the removal of carbon from a engine.
If you believe a 8 dollar can of toxic crap is going to fix your engine then I am done talking.
Old 01-08-2011, 10:17 AM
  #32
Jake_the_Snake's Avatar
for what its worth, ive used it and it neither blew up my motor nor did it foul my spark plugs. car had 155k on the clock when i did it. i did not feel any increase in power or better mileage. what it did do was smooth out my idle, so that alone made the 9 dollar can of seafoam worth it. what i would do is run 2/3 of the can in the gas tank and the rest through the intake. i did not do the oil treatment, but if you choose to, do not drive the car!
if youre afraid of seafoam, ive had alot of people recommend rxp for passing emissions. basically does the same thing, but you only pour it in the gas not the intake. ive used this product myself, again with no problems.
Old 01-08-2011, 11:14 AM
  #33
1badzee's Avatar
Used it on my 185k mile formula. Ran significantly smoother and also uncovered a damn exhaust leak. Probably just a coincidence. Either way, I don't have anything bad to say about the product. Only reason I used it was because my friend had a crap ton laying around and said I can use it. Does it work? Debatable.
Old 01-08-2011, 02:00 PM
  #34
Village Troll
SS RRR's Avatar
I tried, but I can't leave you alone. What exactly did you fail regarding emissions? Using seafoam may be doing nothing more than treating the symptom and not the cause. Probably a good idea to research what you failed instead of spraying seafoam and praying it works...
Old 02-01-2011, 03:48 AM
  #35
AmirGTR's Avatar
I failed smog because my car tends to overheat and use more gas than it should. 11-14mpg is not normal. I figured it needs a PCM a tune. Got the cable and all the programs. I went on the website, and he says do a seafoam first. And I did.
I put half into the gas tank. 1/4 in the oil, and 1/4 in the brake booster. I carefully watched for any changes in oil pressure because I had heard horror stories about chunks of gunky stuff breaking off and getting stuck in the oil lines. Nothing happened.
A coupla minutes after being done feeding it through the brake booster it didn't smoke anymore, eventhough it still had some left in the gas tank and in the oil. Then we change the oil and filter.
Any difference? It seemed to run smoother but could be just placebo. Or maybe it was the 10-50 oil we put in there. Either way about a week or two later my exhaust started to make a lotta noises, could be my cats clogged, or just an exhaust leak. Who knows.
It was worth a shot and cool to watch, and that's about it.
Old 02-01-2011, 05:38 AM
  #36
Did you put it in the brake booster and then wait 20 min, or a couple as in 2?
Old 02-01-2011, 05:52 AM
  #37
Village Troll
SS RRR's Avatar
Ugh... college kids...
Old 02-17-2011, 04:00 AM
  #38
AmirGTR's Avatar
Like I said, because of overheat and the resulting knock. CO2 and the other stuff was fine.
The cure was replacing the coolant sensor and the EGR that had gone bad. Now the fans kick in when they should, and that prevents it from overheating. After these two repairs it passed with flying colors.
Old 02-18-2011, 09:41 PM
  #39
77ihwheeler's Avatar
I just seafoamed a buddies car a few hours and we pulled a vacuum line and put it in the can and that's how we got it in to the engine
Quick Reply: Seafoaming a 17 year old car, good idea?
