Question about LT1 heads
Old Oct 28, 2010 | 03:17 PM
dmuse76's Avatar
Default Question about LT1 heads
On a stock LT1 head, is there much room for porting? basically I'm asking what kind of flow numbers can I realistically expect to get from porting? Heads are stock 94 trans am, don't know casting number is that even makes a difference....
Also, on a stock valve spring/height, what size cam can reliably be run? How big can you go on stock springs?
Thanks in advance!!!!!
Old Oct 28, 2010 | 03:47 PM
RamAir95TA's Avatar
Stock LT1 heads are wonderful for porting. I have a set of AI ported stock castings on my 383. Numbers in sig.
www.advancedinduction.com
And the only cam you can run on the stock springs is the STOCK cam. Any valvetrain upgrade requires a valve spring change.
Old Oct 28, 2010 | 11:53 PM
dmuse76's Avatar
Thank you very much, that is what I needed to know!!!
Old Oct 30, 2010 | 08:44 AM
~BuMps AloT~'s Avatar
Advanced Induction does good work, but Lloyd Elliot does wonders with the stock castings too.
Old Oct 30, 2010 | 08:53 AM
BOLO's Avatar
Both AI and LE have proven LT1 heads in LTX community, especially on this forum.
Old Oct 30, 2010 | 09:03 AM
lordrazo's Avatar
i would agree lloyd elliot and ai are the 2 best
Old Oct 30, 2010 | 01:11 PM
speed_demon24's Avatar
I am satisfied with mine.
