how much do our cars actually weigh?
When it was N/A, my full weight power everything in it 93 weighed in at 3400 lbs. Two tons it ain't. ONLY potential weight saving items were the Firehawk hood and Corbeau seats. Hoping to be just over that now with the turbo kit/intercooler given I also went tubular A-Arms and K-Member.
my originally V6 car, with nothing but the bare necessities and about 30lbs of dynamat weighed 3355 with a 1/2 tank of gas. I've taken out:
abs
ALL EGR and emissions stuff
heat
AC
BUT I've added the 30lbs of sound deadening, a heavy *** GMMG and TA hatch...
These cars should weigh in around 3500lbs without driver and bone stock. Or at least that's what I've come to see.
abs
heat
AC
I never trust those truck scales. They are accurate when weighing TRUCKS/TRAILERS that weigh 10's of thousands of lbs more. It's like trying to accurately weigh a pencil on the spring/type bathroom scale. I bet you could drive around for 5 minutes and get back on the scale and it might tell you 3520, or 3630. The scales at a racetrack where they are meant for cars in the 2500-3800lb range will be a better place to weigh your vehicle.
Weird. A Car and Driver article I've had since it came out states the Camaro Z28 coupe's curb weight is either 3450 or 3550. Can't remember the exact spec.
Mine is a 99 z28 but I weighed here in my town at exactly 3600 lbs with me in it and a completly full tank of gas. I weigh 175 and a full tank of gas is about 95lbs. So my car weighs about 3400 lbs.
#33
3620, with me in it, 3/4 of a tank, no spare tire, no jack, rest of interior still on it, fiberglass hood, stainless steel LTs, rest of car still stock on 17 in WS6 rims and 275 tires
btw I'm only 150 pounds
#35
'95 hardtop, cloth interior, p/w, p/l, Bone stock, 4l60e and manifolds my car weighed 3480 w/o me in it. on a set of scales at the local dump. Just to verify it's legitamacy, I hopped on the scales myself And it accurately showed my weight within 5lbs of my bathroom scales.
#37
#38
how light can you get these cars...I am doing a bbc t-400 car ..its gutted ...i aint afraid to bust out the hole saws and sazall..its all tubular suspension..im shoootin for 2700 to 2800 with out me ...is it possible ?
#39
^^ Hope you are planning on aluminum heads for that BBC. That's 70-80# right there. Also, use an electric fan and an EWP with a low mount alternator and you'll save alot of weight off the front of that thing.
