LT1 Rebuild, On a Budget??? Need help...
I would like to rebuild the motor to be a healthy, reliable motor, that will last a while, and can handle the power of a Hotcam. ( I really dont want to hear about "You should get another cam, etc...", because i've done my research and that is the cam i want...
Anyways,
Should i just replace pistons, bearings, etc.... or buy the whole kit from Summit Racing http://www.summitracing.com/parts/FE...n/?prefilter=0 (Forged Pistons add $100)....
My goals are to have atleast 350rwhp after rebuild with bolt on's listed above, hot cam, and port and polish on stock heads... I would like to spend less than $1500 on the rebuild and machine work (Not including bolt on's, cam, or port/polish)....
What route should i take now that you know my goals/budget?
Thanks in advance,
Kyle
if i did rebuild it, i would probably check the pistons/bores and consider leaving everything stock. just have the block honed/cleaned, and put new cam bearings in. then replace all the other bearings and rings. reassemble.
I'm looking more for street power, but i need reliability because it is my DD... 350-400 rwhp?
I will second the comments about "don't fix what aint broke". With that kind of budget you will endup with a shortblock that is a step backwards from stock. The stock motor is actually pretty darn good. If there are no known problems go ahead and cam it and enjoy.
or you could throw on some LT and the Hotcam without the rebuild and have some $ left over.
Anyways,
Thanks in advance,
Kyle
The kit comes with .010" under bearings, so you'd be looking at having the crank turned if you go the kit way.
I'm not a fan of thin piston rings on a street engine and DEFINITELY NOT LOW TENSION oil rings. Even though the claim is they reduce friction and allow more power, I just don't like them on a DD. In that application, I prefer 5/64th rings; 5/64", 5/64", 3/16" (standard tension, SS50U). Thicker rings help stabilize the pistons in the bores too.
The stock rod bolts are what gives me the most concern, so if I was doing this, ARP rod bolts would DEFINITELY be at the top of my list. Of course now we're talking about having the rods re-sized too.
"Kits" work for some guys but whenever I considered getting one I went part by part and found out I'd always end up with parts I didn't want or need. For example, if I prefer a particular head gasket I'd find DIFFERENT ones included in the kit, etc. So I always ended up buying my parts individually. Hyperuetectic pistons are another example. Kits just don't work for me.
I'd definitely concentrate on close tolerance machine work to nail the bearing clearances, piston to wall/hone, align honed mains, individually setting ring end gaps, decking and balancing.
"( I really dont want to hear about "You should get another cam, etc...", because i've done my research and that is the cam i want..." Don't worry about that. Everytime I post something similar guys ignore my wishes too.
Recently, I CLOSED a thread I started when it got so out of hand with guys telling me what I should and shouldn't do. This was immediately after I pleaded with them NOT TO. Made me so frustrated I just CLOSED the thread.
Jake
If GM can put LT1s together with target service lives all the way up to 300K for the cop car Caprice which has the same exact shortblock as a Camaro I don't see how "bad" a "thin" ring pack can be.
He read some books written in the stone age of "performance" and thinks that means he has the vaguest of clues, he is wrong.
Thanks,
Kyle
