1st time out after new dizzy.
The first thought I have is installation error. Did you make sure to line up the spline or cam dowel correctly? Did it slide in a fully seat before putting bolts in, or did you use the bolts to drive it into position?
Water pump leaks?
Water pump leaks?
I've never had issues like this before, it's gotta be the distributor. The car was fine with the old distributor until the screws backed out of the rotor. I'm gonna see if Nick & I can work something out, I'd like to put the GM opti back in.
