Do you usually re torque head bolts?
What I did with the one head was, after going 15/25/45/75, I backed all the bolts up a bit and re torqed them. The angle did increase after I did this.
My question is, when I get my hands on a REAL torque wrench, should I just check the bolts by tightening them, or backoff and re tighten again? Note that I only have one head on so far and I used the ARP Ultra thread sealer.
Will this fatigue the ARP bolts?
how did this work out for you because i did the same thing
I will re-use the arp's when the time comes though.
Use good thread sealant on the arp bolt threads to stop coolant from seeping up the bolts. Also lube the bolt head/washer for proper torque.
On a side note my 1/2" Craftsman broke a few weeks ago. Took it into Sears and they said tools with complex internals such as a torque wrench are only warrantied for a year.
If you loosen up the bolts you might as well as replace the headgaskets again. Unless it's some hardcore copper headgaskets but if it's Felpro it's a one and done.
As for the Torque to Yeild (TTY) I see people reuse them, but the purpose of those fasteners is to stretch when the angle is applied, it isn't going to kill you motor but if they have been reused several times it might be an issue. There is a guy on youtube that reuses them all the time with a big turbo. On a junkyard 5.3/4.8 LS motor that maybe cost 300 I doubt people want to spend money for the LS ARP bolts.
Ah **** it, I'll respond to my own 10 year old post:
Found out just before Sears shut down they do not have a life time warranty for complex tools, like a torque wrench. Socket wrench, yes. TR, no. Had to replace my 1/2" a few years ago after I torqued down a rear shock bolt in another car and snapped the bolt in half because it didn't click.
