1st time to the track.
Old Nov 6, 2010 | 08:15 PM
gregrob's Avatar
Because my cam only build traps higher than that at 7500 DA!
You got lots of dialing to do
Old Nov 6, 2010 | 08:19 PM
LeonbergerG's Avatar
Dude don't be a dick. Just getting some feedback. First time with this car to the track. I am working in it.
Old Nov 6, 2010 | 08:20 PM
gregrob's Avatar
Im not being a dick. People told you there were several issues with this build when you were putting it together and you wouldn't listen. Now you see the results of that.
Old Nov 6, 2010 | 08:25 PM
What is so wrong. The car does what I want it to and I don't have alot in it.
gregrob's Avatar
Ok. Long as your happy that's what counts.
Old Nov 6, 2010 | 08:28 PM
Plus I'm not running race fuel
If I were it would probably make a good difference. And the can was in the car when u bought it. I worked with what I had
Old Nov 6, 2010 | 08:29 PM
gregrob's Avatar
LMAO
Cam was in the car when I bought it.. sorry
Old Nov 6, 2010 | 08:30 PM
Seriously wtf.
Old Nov 6, 2010 | 08:32 PM
gregrob's Avatar
Race fuel wont make one ******* bit of difference unless you NEED it due to the tune. If you were pulling a **** load of knock, then it would help a little...
Old Nov 6, 2010 | 08:34 PM
Sorry what's pulling knock mean....
Old Nov 6, 2010 | 08:36 PM
  #32
Lawhead's Avatar
Its in the computer where your PCM will pick up knocks therefore retard your timing with 11.5 compression your probably right about racing fuel as well as needing a tune for the racing fuel. idk what gregrob problem is man just don't worry about what "other people" have set up because no matter what there is always bigger better and WAY faster out there
Old Nov 6, 2010 | 08:37 PM
  #33
Thank you.
Old Nov 6, 2010 | 08:38 PM
  #34
I know the compression is high for pump gas
Old Nov 6, 2010 | 08:40 PM
  #35
Lawhead's Avatar
Yeah but like greg said with out a tune your basically pissing into the wind with upping compression go to one of the tuner websites on here and see what they have to say I would keep the car man these LT1's are loads of fun and cheap to make go fast
Old Nov 6, 2010 | 08:41 PM
  #36
gregrob's Avatar
bull ****
Old Nov 6, 2010 | 08:42 PM
  #37
TravisMcGill2000's Avatar
I wouldnt worry bout race fuel. YOu do not need it. Im running 12.1 with 93.. Throw the gear and rr's on if u already got em.. Pull somewieght and sway bar like the other ppl r sayin. Also wat rpms are u shiftin at? More seat time will help also.
  #38
bigj2717's Avatar
The compression it's too high for pump gas. But you are leaving a lot of power on the table. You need to get rid of the shortys and stock exhaust and get longtubes and a exhaust. Also the car is a M6 put the 4.10's in it that you have and some rr's, and if you had the heads off to rebuild the motor why didn't you have any work done to them if you were going to put a cam in
Old Nov 6, 2010 | 08:43 PM
  #39
gorge's Avatar
dude don't sell it, if you are going to sell it sell me some parts from it, JK
nice times
  #40
It is tuned but not for race fuel. I don't think. They may have assumed that it was getting race fuel. But it does have a mail order tune
