LT1 383 Blower Build
Old Nov 13, 2010 | 08:57 AM
  #41
SRZ's Avatar
SRZ
Originally Posted by Blackbirdws6
That's what I will be doing to make sure all the pulleys are perfectly aligned. I've read all about the belt issues so I want to make sure its correct.
I checked the SDCE website but didn't see a LT1 setup listed but just the LS. No pricing either.
You got to call them. Best to just send your bracket to them for them to modify. It's in the 600 range if I'm not mistaken. Ain't cheap but if you throw a few belts, you'll have already paid for it.
Old Nov 17, 2010 | 04:47 PM
  #42
Blackbirdws6's Avatar
Figure I would throw in some pics of the pretty stuff. Awaiting a few parts to get the rotating assembly balanced.
Old Nov 17, 2010 | 04:55 PM
  #43
qc97z's Avatar
Looking good Brian. I'll have to post up some pics of my "repair build" for your enjoyment as well
Old Nov 17, 2010 | 06:48 PM
  #44
96silverram's Avatar
Oh now your just showin' off, Brian I can't wait to see the results of the 21 degree heads and the F1A. Good times ahead for sure
Old Nov 17, 2010 | 07:49 PM
  #45
69gto96z's Avatar
Looking good, cant wait to see it finished up!
Old Nov 17, 2010 | 08:10 PM
  #46
LTXBOI's Avatar
This will be my official build page for the rebuild of my 97 Trans Am. The engine that was just pulled was a stock shortblock with a a head/cam nitrous setup. It ran well but I figured its time to step it up.
FOR SALE THREAD : https://ls1tech.com/forums/parts-cla...l#post14095702
I will keep this updated as often as I can. The goal is to have this ready by Spring.
Engine:
383 LT1 4-bolt splayed mains
Forged JE -31cc Blower Pistons
Forged Callies Dragonslayer Crank
Forged Callies 5.7 Rods
Custom LE Blower Cam
Trickflow 21 deg heads - Worked by LE (ported, polished, new valves, dual springs, etc)
Ported LT1 Intake by LE
Computer:
EFI Connection LS1 PCM Conversion
Blower:
Procharger F1-A 12-rib race system
Race Open Bypass
Trans/Clutch:
McLeod Street Twin
Built Trans (unsure of vendor at the moment)
Fuel:
Twin In-tank Walbro setup
80lb High Imp. Injectors
The new goodies
much props on keeping the lt1 alive.....keep us posted on the build
Old Nov 17, 2010 | 08:34 PM
  #47
Build threads are all the rage now ...do it!
Can't let you have all the fun. I am afraid of your eventual build thread
Me too!!
I like to be a little bit different and I'm happy there is some interesting new stuff on the market.
Stock 97 Timing Cover Vs. TPIS Billet Timing Cover ready for oversized BBC crank hub
Old Nov 17, 2010 | 08:50 PM
  #48
Shownomercy's Avatar
Man-Crush Warning
But how will you run the water pump or opti???
Old Nov 17, 2010 | 10:10 PM
  #49
Flux capacitor or hopes and dreams my friend. EWP and the EFI Connection setup. Never had a problem with my factory opti taken out in working order at 73k. It even went through a water pump failure.
Old Nov 17, 2010 | 10:20 PM
  #50
Man-Crush Warning
Seems to work great for my car!
Any work on the engine bay planned? If you paint it... you can wax it!
Old Nov 17, 2010 | 10:40 PM
  #51
Yup, plan on painting the engine bay. Need to get things cleaned up a bit more first before that happens. I want the fenders to be wire free and glossy
Old Nov 18, 2010 | 01:20 PM
  #52
All that stuff is making me want to go out in the garage and just start tearing the car apart with no plan for what I'm doing, dang you Brian . You have made a ton of progress in a short time. Are you going to polish the F1A? When did TPIS start making a billet timing cover?
More pics or ban
Old Nov 18, 2010 | 05:57 PM
  #53
More pics or ban
Do it!!! I don't see a need to polish the F1A only because you won't really be able to see it. Plus trying to keep it perfect will prob be a huge PITA.
Freakin clutch order got botched but is back on track. Should have been in my hands now.... With the holiday next week, doesn't look like I will be able to get the rotating assembly balanced next week. Guess I will organize the garage.
more part ****....rod bearings, ARP head studs, super damper, oversized BBC crank hub, and misc gaskets came in today.
It's a little bit bigger
Old Nov 28, 2010 | 04:13 PM
  #54
Got some more prep work done on the bird. Hoping to get the rotating assembly balanced this week and get the engine built!!
PREP
The Master at Work (My Dad)
All Done
Old Nov 28, 2010 | 04:19 PM
  #55
Looking good, can't wait to see more results
Old Nov 28, 2010 | 09:18 PM
  #56
qc97z's Avatar
Lol, I just got everything torn out of my engine bay today! Getting ready to clean, mask, and paint myself!
Looks like I'm copying you now....
Looking great Brian!
Old Dec 12, 2010 | 07:45 PM
  #57
And so it begins...
Let me just say I hate piston rings and it will be too soon if I ever have to gap them again. This process took most of the day but nothing to rush here. I will work on this more tomorrow as I took the day off of work to keep playing with it. Everything was within spec and went together fairly well.
Old Dec 12, 2010 | 08:06 PM
  #58
sweetbmxrider's Avatar
major props brian, shortblock looks awesome. i am a little bummed you didn't go with brass freeze out plugs though! dang show cars hahhah
Old Dec 12, 2010 | 08:31 PM
  #59
Haha, I have the brass freeze plugs but its a not a big deal either way. These were installed by the shop that did the machine work. Brass can get loose overtime anyway but in the end, either is fine so I didn't see a need to swap them.
Old Dec 13, 2010 | 08:03 PM
  #60
Rumblin70ss's Avatar
Looks great! Good luck with getting it together!
Who did the machine work on the block?
