94 z28 still has code 36 miss after new opti spark
i have a 1994 z28 with 38k miles, a few months back, car got a bad miss back firing, missing, smoking. you could not even drive car it was missing so bad. so i replaced distributer cap , i put a new opti-spart cap on car, car still has a dead miss, u can actually drive car but it still has a dead miss somewhere, it does seem like it clears up a little when you up in the rpm, but its still there, check engine light comes on and off saying code (36) hight resistance pulse in injetion system, what next ??? could i got a bad apti- spark?? any help would be appreciated
You replaced the cap & rotor only? How did the opti look inside? You won't always see anything wrong with the wheel and resolution sensor if there is a problem with the electronic component. If you only did cap & rotor, you'll unfortunately need to replace the distributor itself. GM (Delphi) is the most preferred unit- you could also try one from Chandler Motorsports (around $140.00 vs. $360.00 for the Delphi). I also put a little red Loc-Tite on the 2 screws that hold the rotor in place. Sometimes they come loose and that's usually pretty destructrive.
might need one of these:
http://www.eficonnection.com/eficonn...spx?ItemId=865
connects from the opti up the passenger side to about 1/2 way back on the intake. carries hi and lo res signals to the PCM so it can command spark timing appropriately. these connectors get chewed up, dirty, corroded, etc.
