fuel system and E85 ?
Old Nov 11, 2010 | 09:50 PM
85iroc94ta's Avatar
Default fuel system and E85 ?
i have done some research on this and have not found what i'm looking for.
i would like to do E85 and a 100 shot of N2O. what size injectors do i need and what fuel pump do i need. And any thing else?
also is there a good wet kit for the N2O. i also need a TB, any suggestions.
the car should be just under 400 rwhp off the N2O may be 500 on the N20.
specs are 94 lt1 .20 over decked, stock heads cleaned up with 1.6 exhaust valves and milled, thinner head gasket, arp rod bolts and main bolts. hot cam kit, pacesetters long tubes, ory, ect.
Old Nov 11, 2010 | 10:05 PM
05HD's Avatar
Extra ~30% capacity for e85 over gasoline.
gregrob's Avatar
42 lbs injectors and dual walbros will do what you need. In the process of swapping to this myself...
Old Nov 11, 2010 | 10:41 PM
SoxXpupPeT's Avatar
Sorry to hijack but what gains would a NA car see running E85 over gas?
Old Nov 11, 2010 | 10:55 PM
RamAir95TA's Avatar
I was told that by switching to E85 (on my setup) that gains of 20-30HP could be had.
Old Nov 11, 2010 | 11:02 PM
gregrob's Avatar
It's more consistent too, if you're into bracket racing.
You can tune for more throttle response, tq, etc.
It's a great fuel if its' readily available to you.
Old Nov 11, 2010 | 11:26 PM
SoxXpupPeT's Avatar
Hmm good information to know guys thanks! its fairly available where i am. Ill look into it when im ready for it one day.
Sorry again to the OP for hi-jacking
Old Nov 12, 2010 | 03:38 AM
Wicked94Z's Avatar
i don't really see the point if you're running a stockish compression motor. the gains won't be too substantial for the cash outlay (pumps, injectors, retuning, etc). Running alcohol your tuning window broadens, which helps the carb guys more than us. Basically there might not be much power difference in 3 or 4 points of A/F ratio. Not saying you can get by with shitty tuning, but the car won't be as sensitive to weather changes, especially IAT since the fuel will cool the intake charge somewhat.
Old Nov 12, 2010 | 06:22 AM
moehorsepower's Avatar
Yup ^^,what he says....
