Coolant cross over back of the head question.
Old Nov 18, 2010 | 01:40 PM
whytryz28's Avatar
Default Coolant cross over back of the head question.
For those who have broke the originals removing the heads, what did you use to replace them? Ive tried Home Depot and the parts store for brass fitting but they dont have anything in stock I can use.
pics would be helpful.
Old Nov 18, 2010 | 01:43 PM
RamAir95TA's Avatar
Use a pipe tap on them and you can get fittings to fit from Earls. I ended up picking up about $40 in fittings and made it work. Pretty sure they were -6AN.
Old Nov 18, 2010 | 01:47 PM
RamAir95TA's Avatar
Here, this should help:
https://ls1tech.com/forums/lt1-lt4-m...-pictures.html
Old Nov 18, 2010 | 01:52 PM
*CAMARO*'s Avatar
That definetely looks better than the stock coolant crossover and cheaper to boot.
Old Nov 18, 2010 | 06:57 PM
LT1-TA's Avatar
they started to manufacture the bolts aftermarket so they are available if you want to put it back the way it was.ill try and find the link if you want
Old Nov 18, 2010 | 07:50 PM
quik95lt1's Avatar
2 3/8npt to -6an 90* fitting
1 3/8npt to 6an to -6an T fitting
1 -6an to -6an female coupler
3 ft of -6an hose
3 -6an hose ends
that was my list
or u can ditch the hose for hard aluminum line with hose nuts and sleeves
Old Nov 21, 2010 | 01:39 PM
whytryz28's Avatar
So is it 3/8 npt or 1/4 npt for the back of the head? Just got my heads ready to be thrown on and need buy all this crap lol
Old Nov 21, 2010 | 05:13 PM
RamAir95TA's Avatar
I used a pipe tap for 1/4" NPT.
Old Nov 21, 2010 | 07:31 PM
mean_greenZ's Avatar
here is mine.
Old Nov 22, 2010 | 04:54 PM
LT1559's Avatar
lol i was lazy and cheap, i just cut the line where it bent and broke, then put a rubber hose to connect both ends and clamped them together. it's held for close to 2 months now.
Old Nov 22, 2010 | 04:55 PM
LT1559's Avatar
meangreen, your setup is nice
Old Nov 22, 2010 | 08:12 PM
whytryz28's Avatar
Damn I should have done that, oh well went to Lowes and raided the plumbing section. Only cost me $8, sorry but im not paying $50 for ******* fittings no one will ever see.
Old Nov 23, 2010 | 08:27 AM
Jazz-LT1's Avatar
That's definitely nice. I still have the original crossover pipe, but if the heads are ever off the car again I'll definitely make this conversion.
