security system wont start
Old Nov 22, 2010 | 09:08 PM
77ihwheeler's Avatar
Default security system wont start
I have a 94 z28 that I recently crashed I replaced the front end and had to replace the dash board and both airways and all the sensors and computer for the airbags after I took the dash apart the security system won't turn off and my car won't start. Any ideas?
Old Nov 22, 2010 | 09:14 PM
94maro's Avatar
get the vats deleted out of the comp with a good tuner
Old Nov 22, 2010 | 09:17 PM
tricked94camaro's Avatar
is the key still good?
Old Nov 22, 2010 | 09:22 PM
LT1's Avatar
LT1
You can bypass the vats, shbox website link shows how. Most likely your orange/white wire (to the lock cylinder) is either open or short to ground which could cause the security light to come on.
http://shbox.com/1/vats_bypass.jpg
Old Nov 23, 2010 | 03:25 PM
ok thank you im going to try to bypass the vats system and hopefully it works
Old Nov 23, 2010 | 03:33 PM
why would it have stopped working when i replaced my dash or is it just a coincidental thing
Old Nov 24, 2010 | 01:08 AM
LT1's Avatar
LT1
Have you got a chance to see if the lock cylinder wire (orange and white) is disconnected or broken? If it were to break usually at the back of the lock cylinder where the wire sits.
You might have just not reconnected that vats wire connector to lock cylinder wire connector, or just a bad chip in your key.
This link is another helpful link to bypass vats
http://vats.likeabigdog.com/
I like shbox link better its simple to understand.
This link shows how to find out what value resistance in ohms that your key has
http://shbox.com/1/4th_gen_tech2.html#pass_key
Old Nov 24, 2010 | 08:24 AM
i checked the vats wiring under the dash last night and it seemed fine of what i could see but i did not trace it up the steering column or check it at the back of the lock cylinder
i just checked my key and i got a reading of 680 so a Pellet code 3
im going to try to test the key and lock cylinder resistance tonight and if that ends up checking out fine i will just wire around the vats system
Old Nov 26, 2010 | 03:59 PM
I just tried wiring around the vats system with a 680 resistor and still nothing happened I'm really at a lose as to what's wrong with this car please help
Old Nov 26, 2010 | 05:20 PM
I was just reading through my chiltons manual and its saying to unlock the delco-loc ii system I have to do a bunch of stuff with entering a code into the stereo could this be related to my problem and if so I don't have the stock stereo anymore or know the code so how do I go about unlocking it
Old Nov 29, 2010 | 10:25 PM
LT1's Avatar
LT1
The delco radio doesn't have anything to do with the security light.
Is the vats module still in the car?
Did you get the correct resistor? Where did you install the resistor?
Old Nov 30, 2010 | 12:53 PM
i did get the resistor and put it in the right spot i figured out what the problem was when i replaced the passernger airbag i didnt realize that the computer for the security system is the one on the airbag bracket so i used the one that was on the new airbag bracket but once i figured that out and torn the dash back out and put the old one in it started up just fine and i left the resistor in there so i wont have to deal with that isssue coming up
Old Nov 30, 2010 | 03:41 PM
litch2004's Avatar
That would be why. The new card module on the bracket had a new value on it. Sell it. Someone might need it.
Old Dec 1, 2010 | 06:27 PM
LT1's Avatar
LT1
Good to hear, glad you were able to figure it out.
Old Dec 1, 2010 | 09:31 PM
I need to get a hold of the guy I got it from and ask him to test his key to I know the pellet code before I sell any ideas how much those things are worth used and also if the airbags deploy does the airbag computer have to be replaced or is it reusable
