any lt1 guys running e85?
Old Sep 9, 2015 | 02:38 PM
Brfirebird91's Avatar
Originally Posted by BIGsmokey10
How much flywheel hp you looking for?
And just to specify when you say your gonna do a 200 shot is that wet shot or dry ?
Well I hope my car be in the range of 400 to 450 Rwhp n/a I think. So maybe at the flywheel 450 to 500hp. Also NX Gemini Wet Shot.
Old Sep 9, 2015 | 02:53 PM
BIGsmokey10's Avatar
Some 42 lb injectors with the fuel pressure bumped up to 4 Bar will work . That will give you about a 47lb injector which will cover 500fwhp on e85
I personally use 60 lb Siemens deka and have good results with e85 and stock ecu
Old Sep 9, 2015 | 03:05 PM
Would you suggest I run 60lbs that was my main idea to run. Can you give some good injectors to run.? Like brand or name.?
Old Sep 9, 2015 | 03:35 PM
I gave you the ones I run in the above post . Siemens deka 60 lb injectors . Bought them threw fuel injector connection
https://secure.fuelinjectorconnectio...-ev1-plug.html
Old Sep 9, 2015 | 03:44 PM
Got it. Very much Appreciate the help. Thanks you
