Single Plane intake which elbow do I use?
Old Dec 31, 2010 | 08:02 PM
  #41
T/A KID's Avatar
Got a Ported SuperVIC on my setup, ported the plenum (pulled the walls back) and built me a large aluminum elbow opened to the plenum, mounted a Monoblade to it.
Old Dec 31, 2010 | 09:07 PM
  #42
Wicked94Z's Avatar
whatever happened to your modded LTx manifold? got pics?
Old Jan 1, 2011 | 12:45 AM
  #43
T/A KID's Avatar
I have pics on my digital camera, but not uploaded to my photobucket account. I Still have my modded LTX intake, just setting on my shelf in my shop.
I actually just started the car up today (haven't messed with it in 9 months) installed a new EFI connection setup, and having Race Proven Motorsports tune it via my Hptuners/LM1 wideband (no tuners where I live unfortunatly)
Old Jan 1, 2011 | 07:36 AM
  #44
96capricemgr's Avatar
I agree dual plane would not the the right way to go BUT there are single planes rated for under 8500rpms which seems to be what you guys like to choose. Same problem folks have with cams "more is better".
Old Feb 23, 2011 | 05:23 PM
  #45
T/A KID's Avatar
Just uploaded some pics, figured Id post up my Supervic setup thats on my Procharged 383. Don't have to spend a lot of money to go this route if you do stuff yourself (been there done that as well) I bought some some stainless steel 30 degree washers and that fixed my bolt angle problem and it looks very clean ( I believe I cut thta angle done some, been over a year since I have did all of this.
This is a super vic for a vortec engine (slightly taller than a SBC super vic) and between my elbow, 5.63inch super vic, and a 3/8 spacer it fits my stock Ws6 hood (LS1 front end conversion).
Looks killer and I have less than $400 in the whole thing
Old Feb 23, 2011 | 10:29 PM
  #46
robsquikz28's Avatar
im loving the color scheme
Old Feb 24, 2011 | 05:18 AM
  #47
FASTFATBOY's Avatar
Cam determines sign off RPM, not the heads or intake. My car made 430 ft lbs of tq, made 400 at 3000 rpm. And yes I will admit my combination is "off", it needs a little more cam to really move. But I like its street manners.
The Z06 MAF will support damn near any N/A setup that can be put behind it.
My car needs the tune touched up, no time for it right now. With the new converter it has traction issues, it has never been scaled I just been throwing darts.
IMO the single plane is a good mod, just have it worked if you gonna run alot of cylinder pressure, end cylinders will be lean.
Old Feb 24, 2011 | 06:15 AM
  #48
SickSixSpeed's Avatar
what do you do about the maf with a 4150 style throttle body?
Old Feb 24, 2011 | 06:45 AM
  #49
Tensec94z's Avatar
Here you go,its a Lingenfelter MAF with a carb hat.
  #50
FASTFATBOY's Avatar
Old Feb 24, 2011 | 08:25 PM
  #51
how would i go about getting around the carb hat, intake piping and mass air? i just bought a set of dart 230's from lt1powr and im trying to figure everything out. also where do you guys get the intakes without water necks and distributor holes?
Old Feb 24, 2011 | 08:38 PM
  #52
Puck's Avatar
You don't get them like that, they have to be converted over and machined.
Old Feb 24, 2011 | 10:22 PM
  #53
Wicked94Z's Avatar
they look pretty sick that way too... my stealth ram is at the machine shop right now getting converted
Old Feb 24, 2011 | 10:52 PM
  #54
how much would that run? also could i just block it off?
Old Feb 25, 2011 | 02:30 AM
  #55
Wicked94Z's Avatar
yea i'm getting an aluminum plug made for the dizzy hole, a thermostat housing delete is probably 150 bucks or so, just guessing on other machine work/welding i've had done
Old Feb 28, 2011 | 12:20 AM
  #56
1961ba427's Avatar
Okay, this is going to be maybe a crazy idea, and I'm not sure if any of you are old enough to even know the intake I am speaking of....but here goes:
Offenhauser makes a single plane, dual four barrel manifold. The runners all sit level so it wouldn't be hard to machine them for injectors. Shouldn't be that bad to build a box type plenum with a removeable top to bolt down to the carb pads. Same similar concept as Weiand taking there Hi-Ram tunnel ram and making the Stealth Ram....it just wouldn't be nearly as tall.
Also I was thinking....instead of blocking off the distributor hole in the back of converted intakes, why doesn't everyone just run a distributor to drive the oil pump and just not have it hooked up at all? Seems like there has been alot of lt1 oil drive gear problems, and something like the vortec distributor would fit back there. I know that several companies also make drop in distributor "plugs" or whatever they call them for people going to a front, belt drive distributor, but wouldn't what I mentioned work and be pretty much free? Noone would even see it back up under that windshield. lol
Old Feb 28, 2011 | 09:15 AM
  #57
will the nitrous outlet elbow clear a stock camaro hood/cowl? also where did you get your carb hat fastfatboy and how much was it?
Old Mar 1, 2011 | 12:39 AM
  #58
hitmanws6's Avatar
^^with a Vic E intake yes. Formula383 had one on his and it cleared the cowl
Old Mar 1, 2011 | 08:45 PM
  #59
Wicked94Z's Avatar
I'm not old at all, but I started off at 13 with my great uncle (he's 96 now!) and an '66 studebaker with a 230ci chevy motor. We did a single 4bbl offy intake, a 214º cam and a set of headers. It was a fun little car, even if I couldn't drive it at the time. I'm guessing this is the offy dual quad intake you're referring to?
http://www.aaamarine.com/servlet/the...sb-Chev/Detail
Old Mar 1, 2011 | 09:44 PM
  #60
1961ba427's Avatar
Yes that is it. I actually am not familiar with the sbc one, but I am with both the 348/409 models. Unlike most dual four barrel intakes, they are a single plane with one large common plenum. There is a plenum divider, but it can be removed entirely, or trimmed down for tuning. I bet a plenum "box" bolted to the top and some injector bungs could make for a fun intake.
I have a friend who used to run one on a solid roller 468 with just a pair of 1850 holley 600's on it.....but it was plumbed for a fogger and had a plate under each carb. He never took the car to the track, but I witnessed him take money from alot of people. Some cars were even trailered (supposedly 9 sec cars) in to the street racing spot and got embarrased. His car (68 SS camaro) was not modded that far from stock and looked and even sounded like a healthy resto than an all out drag car. It didn't even have a cowl hood....just the factory SS one with the little chrome bulges. The only visual clues were wheels/tires, a sumped stock tank, and full 3" exhaust routed like stock. I'm sure alot of his wins were due to great traction. He found that a 3.55:1 gear worked best in it with the street tires he ran. I think they were M&H, but it's been about ten years. I know they were not the old M/T dot bias plies that they had before the ET streets. I'm sure his car would have ripped on a set of what's available now.
