Single Plane intake which elbow do I use?
Otherwise the 860 + vic E + 58mm TB would be my second choice.
http://advancedinduction.com/AiEngines.html
Not a victor intake.
Like I said earlier, most actually flow LESS then a quality dual 58mm LTX TB...but in certain situations you may benefit from the straighter shot of air.
I haven't seen enough back to back testing to see how much hp and how many RPMs you need to spin for it to be worth it, but for most people I would say its a waste of money.
FFB recently did the conversion but doesn't have much hard data yet...
Vic Jr E Intake
Edelbrock Low Profile Elbow
FLP 90mm TB
I had the heads redrilled for the SBC bolt pattern from TEA. The throttle response is night and day from my old ported LTX intake and 58mm TB.
Vic Jr E Intake
FLP 90mm TB
https://ls1tech.com/forums/picture.p...ictureid=41074
https://ls1tech.com/forums/picture.p...ictureid=43923
https://ls1tech.com/forums/picture.p...ictureid=43921
https://ls1tech.com/forums/picture.p...ictureid=41078
https://ls1tech.com/forums/picture.p...ictureid=41076
Other than that your motor is very clean, how do you like the 24x? I'll be ordering mine in the spring when my suspension is finished, I'm just having a hard time spending more money on the harness than I am for a watts link
But I know it will be worth itCaprice, the AI setup looks good, but I think there are other options out there too, but a bolt on setup would be nice. I would rather see the setup with the water neck on the intake cut off, but I have a local guy that can do that for me at a decent price. I know its just a cosmetic thing, but if I'm going to be dropping a lot of coin on something I want it to look as good as it functions
Here is an actual dyno graph for this mod.
https://ls1tech.com/forums/lt1-lt4-m...ml#post5929007
I guess I'll see when my time comes. But when I do my switch I should have a new motor built. But if I end up doing the 24x kit in the spring (possible opti problems) I'll probably do the single plane/LSx throttle body/100mm MAF. That way its already done and I don't have to change the $850 wiring harness when my new motor is ready to install.
My new motor should easily spin to 8000 rpms (not saying I'm going to shift it there, but it should be able to rev that high). I have considered a dual plane intake with an elbow and LS style throttle body, but then I would have to drill the bungs for the injectors and the vic e intake already has all of that done. I'm still researching my options but I want to get away from the LT1 intake, and have had the dual plane intake bouncing around in my head for a while.
But your saying that if the guy with the dyno graph would have had his intake ported and cleaned up it would have matched the performance of the LTx manifold? Thats what I assumed, but want to be sure.
What some guys are doing to them with a grinder is pure art.
