LTCC coil conversion
Old Dec 11, 2010 | 08:46 PM
BOLO's Avatar
Originally Posted by chief455
if I read the tech correctly - we need to run a 96-97 4L60E in any 93-97 car for the EFI conversion.
I wonder if swapping the 96-97 internal selonoids and harness/plugs into the OBD 1 trans would make it work?...
It will probably take more than harness and solenoids. If I ever decide on this conversion, it will be on the next build along with a TH350 or TH400.
Old Jan 13, 2020 | 11:23 AM
Adam Prostreet's Avatar
Default Ltcc nitrous retard
Hi I have a 94 lt1 with the ltcc and I was wondering if you know the correct position of the mode dip switch inside the box to active the nitrous retard. I know it’s says 1,2,3,and 4 but I only see two switches up and down. I know it also activates the two step hard or soft cut rev limiter. Do you have a picture of inside your box with the retard on?
Old Jan 17, 2020 | 02:33 PM
KW Baraka's Avatar
......you open up a nine year-old thread and expect an answer from a who isn't on the forum anymore and no longer has the car?
Really?
KW
Old Jan 20, 2020 | 09:48 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Welcome Adam to LS1tech!
From the instruction guide:
There is a 4 Position “Mode” Dip Switch inside the unit that has the following functions;
Mode 1 . Off=Soft-Touch Rev Limiter ; On=Hard Cut Off Rev Limiter
Mode 2 . Off= Energize 2-step Input to Activate ; On= De-Energize 2-step Input to Activate
Mode 3 . Determines 4x Low-Res Decode Mode. Off=rising edge, On = Falling edge (Leave this off)
Mode 4 . Off= N.O.S. Retard Activated by 2-step Input ; On = Low Rev Limit Activated by 2-step Input.
