Low Oil Level Sensor
Old Dec 3, 2010 | 10:17 PM
LarsV8's Avatar
Default Low Oil Level Sensor
It looks like I am leaking oil at the low oil level sensor. The sensor itself is brand new.
Ive read that the connector can leak.
Couple of questions:
1.) Is this sensor usually sealed with some sort of adhesive?
2.) Could I just possibly replace the connector to fix the leak?
2a.) Anyone have a part number for the connector?
Thanks!
Old Dec 4, 2010 | 01:25 AM
my1994z28's Avatar
There should be a seal on the sensor.or if the seal is on it,could be you got a bad sensor.usually when oil starts coming out of where the connector plugs in the sensor is no good.
Old Dec 4, 2010 | 04:40 AM
S10Wildside's Avatar
It is impossible for the connector to be the source of a leak.
Old Dec 4, 2010 | 10:00 AM
BlackBird87's Avatar
Mine leaked from the inside of the connector. Might have been due to the fact that it was never plugged in but i bought an oil drain plug and that fixed it
Old Dec 4, 2010 | 08:43 PM
flame's Avatar
The connector is not designed to retain oil. The sensor is not supposed to leak.
Old Dec 5, 2010 | 08:35 AM
leadfoot4's Avatar
It should be an easy fix, as the "seal" is actually an o-ring. Simply put a new one in place, and tighten it carefully, making sure the ring stays in the groove. If it does leak at that point, yes, I would say that "anything's possible", and just maybe the part itself is seeping...
Old Dec 5, 2010 | 02:47 PM
LarsV8's Avatar
Do you know the torque spec by chance?
The old one was metal but the new one is plastic, so I am afraid to overtighten for fear of breaking it.
Old Dec 5, 2010 | 03:24 PM
That's only possible if the sensor housing is cracked.
Old Dec 5, 2010 | 03:30 PM
hawk584's Avatar
rockauto.com
-ACDELCO Part # D8055 ;$17.40
-AIRTEX / WELLS Part # 5S3003; $15.43
-STANDARD MOTOR PRODUCTS Part # FLS14;$14.76
Old Dec 5, 2010 | 03:55 PM
LarsV8's Avatar
Originally Posted by hawk584
rockauto.com
Thank you,
however i am actually looking for the connector piece (the one attached to the wiring harness) and not the sensor itself
Old Dec 5, 2010 | 04:05 PM
hawk584's Avatar
hunt around on rockauto.com, you might find that piece
Old Dec 5, 2010 | 05:07 PM
leadfoot4's Avatar
Mine is plastic also. I used a crescent wrench, but obviously "snugged it up" very carefully. You just need to get a little bit of "crush" on the o-ring. Off hand, I'd say around 7-8 ft/lbs.....
