T-56 max hp
Old Dec 6, 2010 | 07:03 PM
gregrob's Avatar
Default T-56 max hp
Mine is built with billet keys, brass fork pads, steel 3-4 fork, CF blocker rings in the synchros, brass shifter cup, etc.
Needs to hold 1000 FWHP.
Discuss
Old Dec 6, 2010 | 07:05 PM
LSWHO's Avatar
Originally Posted by gregrob
etc.
I like this. Leaves the whole thing wide open!
Old Dec 6, 2010 | 07:28 PM
Wicked94Z's Avatar
needs a viper shaft at a minimum. what's the intended usage?
Old Dec 6, 2010 | 07:31 PM
gregrob's Avatar
Lswho stfu. Its a standard non-viper build... not that hard to figure out
Wicked. Street, drag, road race.. needs to be pretty tough. Do you mean viper main shaft, or input, output, ?
I know ill need a street twin or similar as well.
Old Dec 6, 2010 | 07:54 PM
AChotrod's Avatar
Although stock output shafts are NOT known as a common failure I snapped one like a twig. If I ever build mine again It will get the Viper output.
Old Dec 6, 2010 | 08:00 PM
Wicked94Z's Avatar
Viper mainshaft. That powerlevel, especially trying to road race it (!!!!) you're going to be generating ALOT of heat in the trans. You'll probably need to add an oil pump + direct oiling to it as to not starve the gears during long highway/straightaway pulls. The gearset is a weakness at that powerlevel too. How deep are your pockets?
Old Dec 6, 2010 | 08:02 PM
Wicked94Z's Avatar
**** that t56, throw the th350 in it
Seriously I weighed my options, and even after throwing 2k into a T56 there's no guarantees. That's why i ditched it, I don't have the money to repair stuff like that, I'd rather build it and freshen every few years.
Old Dec 6, 2010 | 08:04 PM
AChotrod's Avatar
Once I break it thats the plan.
Old Dec 6, 2010 | 08:49 PM
gregrob's Avatar
Deep enough but I won't keep throwing money at it either if it won't live.
Road racing will only be 3-4 times per year and I plan to neuter the tune as much as possible so I don't kill myself. The motor makes 800+ fwhp N/A but with the elevation and a super mild tune I can probably get that down to 550ish at the tires
Old Dec 6, 2010 | 08:51 PM
gregrob's Avatar
At the strip it will be on kill mode and have a little whiff of gas
Old Dec 6, 2010 | 08:54 PM
Wicked94Z's Avatar
strip mode is going to give you problems I think
Old Dec 6, 2010 | 08:58 PM
gregrob's Avatar
Probably. Guess what, its got a ginormous elephant dick cam!!! You would be proud
Old Dec 6, 2010 | 09:05 PM
Wicked94Z's Avatar
Very proud indeed! No such thing as too much cam. Just not enough head, rpm, cubes, gear, converter, and weight reduction.
Old Dec 6, 2010 | 09:21 PM
gregrob's Avatar
**** yeah. It has ahem "plenty cam taming cubes" let's just say
Old Dec 6, 2010 | 09:59 PM
Wicked94Z's Avatar
pm the engine combo. i'm guess bbc
Old Dec 7, 2010 | 09:59 AM
69gto96z's Avatar
I would like to know this also. I have grenaded 3 of them. First one lost 2nd gear, Second one lost 4th gear, the one I have now the 3-4 synchro is messed up. I am hard on my car, but with EVERY shift the clutch is always pressed in fully, and my car doesn't make that much power. I thought the T56 was supposed to be fairly strong?
Old Dec 7, 2010 | 11:53 AM
bigj2717's Avatar
I believe it's 96+ that have a improved 2nd gear the earlier ones had a weaker on. A lot of companies are now doing SSR output shafts and main shafts since they are stronger then the viper ones.
Old Dec 8, 2010 | 08:55 PM
97Z28SS's Avatar
Spend the money for a Tranzilla (1200hp & 1100tq) or the son of tranzilla (900hp & 700tq).
Old Dec 8, 2010 | 09:55 PM
bigj2717's Avatar
You're joking right? Do you know how much those cost? You can have one built for the same power rating from any of the sponsors for less then half of those.
Old Dec 8, 2010 | 10:44 PM
camar0corey's Avatar
Obviously you should run a stock T5 out of a third gen.
