Another LT1 cam swap
I'm running the xe 230/236 and I love it. My heads are mildly ported though. There is a thread I just posted a week or so ago with an idle vid. I will say it is a lot of can for factory heads and without other supporting mods. I have every supporting mod I can think of for it and trust me it gets pricey. A lot more that I predicted. Also you would need bigger injectors. My factory 93 objectors ( lowest of the lt1s) were at 95%.
+100000000000
Both of my lt1 cars, each way, this is by far the easiest thing to do. You arnt reusing them. It doesnt matter, grab your jack handle and thightin them till they snap. Hell, some of mine did it loosening them.
well there has been a change of mind... Sence i am this deep into it im going to have LE do the heads. I would like to get AI heads but i dont have that much cabbage.
I am going way over my budget but i will regret it later if i dont do it now.
HA! You wanna talk about going over budget? My simple heads and cam swap that was ONLY supposed to cost me $1,200 in labor, is now at $4,300 because of a bad cylinder wall that had to be machined. FML!!!
I apologize if this is considered thread jacking, but the question of hub orientation is giving me a little concern. The absence of a woodruff key on the LT1 suggests strongly that it doesn't matter. Does it?
Best -- Gary
It is evident that skepticism, while it makes no actual change in man, always makes him feel better. -- Ambrose Bierce
Best -- Gary
