opinions on a cam
Old Dec 12, 2010 | 10:06 PM
VinR1's Avatar
Default opinions on a cam
One a friend is considering purchasing for an otherwise stock LT1
Straight off the card
Duration at .050 218/224
Separation (??). 111
Gross valve lift. .510 .510
LSA. 106
stock 1.5 RRs
Goals are DD/weekend warrior with plans of lt's ,heads ported, stall, etc...
TIA
Old Dec 12, 2010 | 10:08 PM
LSWHO's Avatar
sounds like a small torque friendly cam. 106 LSA seems odd... now that I look again, you have separation as 111? and at 106?
Old Dec 12, 2010 | 10:13 PM
RamAir95TA's Avatar
If you're sure you're going to do heads, wait until then to select a cam.
Old Dec 12, 2010 | 10:14 PM
DVS LT1's Avatar
Yes those are almost conflicting specs on the lob separation angle - I'd believe a 111 LSA over a 106 - 106 would be a HUGE overlap wouldn't it? Even a 111 LSA would make that cam pretty ballsy.
Besides the 111 LSA (if it is), aren't those specs close to a Hot Cam's? (w/ a 1.6 the lift would probably be close to .525; duration seems close). If I remember correctly the hot cam has a 112 LSA.
Stock heads - I'd say dump a GM 847 cam in that things and rev the **** out of her!!!
Old Dec 12, 2010 | 10:17 PM
hitmanws6's Avatar
I say custom grind. I was going to go with a GM 847 initially, but i liked what LE specd me instead.
Old Dec 12, 2010 | 10:33 PM
VinR1's Avatar
On the card it has 111 next to 'separation' and 106 next to 'angle separation intake lobe...' Then the bottom of the card and I can't see the rest of the sentence
Old Dec 12, 2010 | 10:51 PM
speed_demon24's Avatar
Seems decent.
Old Dec 12, 2010 | 11:13 PM
trilkb's Avatar
with 1.6rr it would be .544/.544. That LSA is kind of funky, i beleive that just changes your power curve or peak power to a lower rpm? some people say 50-100rpm for every 1 LSA? like 112 could peak at 6200 and 110 could peak at 6100/6000 depending how you think of it.
I could be wrong, im still learning. I just know 106Lsa will hurt your vaccum.
Old Dec 13, 2010 | 08:42 AM
VinR1's Avatar
again, its not for me. basically, I was handed a card and asked what I thought of it... I compared it to the cams in the sticky and told him it looked like a hot cam with a nasty idle
Old Dec 13, 2010 | 08:47 AM
white84z's Avatar
It's ground on a 111 lsa with 5 degrees of advance ground in. So dot to dot its advanced 5 degrees, most shelf cams are advanced around 4 degrees iirc, it helps boost the low end but the cam runs out of steam faster.
Old Dec 13, 2010 | 08:51 AM
VinR1's Avatar
that makes sense
