nitrous outlet
Old Dec 27, 2010 | 09:01 AM
camar0corey's Avatar
I'm still gathering pieces for my setup(embarrassingly over the last 3-4 years!). I went with Nitrous Outlet, their customer service is top notch. You can't go wrong with the LT1 specific kit for what you want to do. Everything is included for a clean install.
Also are you going to use a bottle heater or NANO?
Old Dec 27, 2010 | 09:46 AM
alexcoreas's Avatar
See that's what I don't get I saw they had a bottle heater as an added extra, but here is what I don't get they also have an intercooler for it. I need to do some homework.
nitrous is definitely the route I'm going. Should I build my bottom end? Currently has 80,250 miles no leaks or problems.
Old Dec 27, 2010 | 11:01 AM
AChotrod's Avatar
I added a lot to it like a Nano and stand alone fuel system etc. etc. I never dynoed it on spray, but NA it made 413rwhp so Id say about 560 or so on the 150shot and could up the jets easy.
I also have forged pistons and ARP hardware in the short block, but a lot of people spray 100-150 on stock short blocks, just make sure your tune is good
Old Dec 27, 2010 | 11:35 AM
alexcoreas's Avatar
Yea I hear a lot of ppl spraying on stock blocks, I don't wanna shortcut anything
And blow something.
How do you like your kit so far?
Old Dec 27, 2010 | 12:03 PM
AChotrod's Avatar
Its awesome but I finished it late in the yr so Ive just done some street testing with it. It works great and like I said puts a smile on my face every time I hit it. Heres the system
Old Dec 27, 2010 | 12:46 PM
alexcoreas's Avatar
WOW that's a real clean EVERYTHING!!!!!!! I just did a lot of reading on nitrous setups . How does someone avoid nitrous backfire? How much did it cost to build your motor for nitrous?
My budget is only 4grand and ill wait if that's not enough I want it done once.
And right. You've been a lot of help
Old Dec 27, 2010 | 01:18 PM
AChotrod's Avatar
Thanks, I try and keep it that way.
4k is not enough to do it right and from scratch, but if you buy used stuff its possible. I would just spray the bottom end and rebuild it when it blows up. Put the money into the top end and nitrous system.
As far as nitrous backfires, a quality system,window switch, tune,plugs and only spraying it at WOT above 3k is about the best you can do.
Old Dec 27, 2010 | 01:39 PM
alexcoreas's Avatar
Ill do just that topend first AI H.C.I. and nitrous. Its not like ima spray it everyday lol I hope not.
What kind of internal work would I need for a nitrous build I tried looking it up but no useful info was found. Maybe you have a link?
Old Dec 27, 2010 | 01:52 PM
Choppers's Avatar
Most people like to have forged internals.
Old Dec 27, 2010 | 02:08 PM
AChotrod's Avatar
Forged pistons, good hardware, some scat or eagle forged I beams and a stock crank is a good start for a cheap build 350, prob dont need the rods until 500+hp or so.
A fully forged motor is the only way to go if you build a stroker motor.
Old Dec 27, 2010 | 02:45 PM
alexcoreas's Avatar
Thanks a lot.
Old Dec 28, 2010 | 11:17 PM
  #32
spike30th's Avatar
So since you guys are on this topic maybe you all can give me idea what my engine can handle. I have a 383 with a 2 bolt main all forged internals the rings have been gapped for nitrous, and arp hardware. NA the car dynoed 413 rwhp. I bought a nitrous outlet Plate wet kit with all the safety stuff.my question is what size shot you all think safely my engine can handle?
