nitrous outlet
Old Dec 24, 2010 | 04:21 PM
alexcoreas's Avatar
Default nitrous outlet
Ok so I was browsing the nitrous outlet website how do I know which setup is best for me?
I am building my motor around nitrous Max HP/tq I want to achieve is 550 rw.
Is nitrous a lot more complicating then running a Turbo or supercharger? Which one turns out to be the most expensive route?
Thanks for the help
Old Dec 24, 2010 | 07:47 PM
alexcoreas's Avatar
Not that many ppl spray?
Old Dec 24, 2010 | 08:01 PM
Lawhead's Avatar
TONSSSSSS of people spray
http://www.nitrousoutlet.com/catalog...=14&section=37
scroll down to the LT1 section on there I think thats what your wanting wet kit is the way to go i always thought it adds extra fuel and we all know you don't want to run N20 Lean or crazy things happen and you end up like a mustang on the side of the road 0__0
Old Dec 24, 2010 | 08:12 PM
ZGOBYBY's Avatar
Thanks for the help
I think if you are going for BIG power builds, they all end up costing. But, nitrous seems to be very popular, and can be done on a budget. As for the turbo route, I love it, but LT1s do not enjoy boost if they are not built to handle it. I am sure if you give Nitrous Outlet a call, they will set you up with the right set-up. Those guys are great from that company.
Old Dec 24, 2010 | 08:22 PM
MattSapp95_T/A's Avatar
I would say for what you are wanting a mild heads cam build with a 150 shot would be much cheaper and easier than boost...
Old Dec 24, 2010 | 10:46 PM
red93z28lt1's Avatar
or just get heads and a nasty cam and get power all the time....forget the boost!
Old Dec 24, 2010 | 11:17 PM
This with spray..
Old Dec 24, 2010 | 11:20 PM
or that but remember do things in order or all at once
Old Dec 25, 2010 | 12:22 AM
BADMOON's Avatar
Thanks for the help
I hear Nitrous Outlet makes LT1 cars go LUDACRIS SPEED
Old Dec 25, 2010 | 06:09 AM
gregrob's Avatar
******* SPRAY IT
Old Dec 25, 2010 | 09:51 AM
Miller95z28's Avatar
SPRAY ITT.. youll be addicted, i have the nitrous outlet wet plate kit and pilled for a 100 shot on a bone sock motor and its great,kit is simple and easy to put on and worth the money,
Old Dec 25, 2010 | 10:27 AM
alexcoreas's Avatar
Exactly what all of you say. I'm doing it all at once since my grandparents are buying me the kit . I decided to go the nitrous outlet route. Since I don't have to worry about buying it only thing I have to worry about is the engine build.
AI. WOULD BE able to help me out with a H/c/I package right?
is nitrous an easy way for me to reach my goals or are they unrealistic?
Old Dec 25, 2010 | 01:00 PM
86formula's Avatar
500 at the wheels is easy through an M6 with heads/cam and spray. you could do that with a stock bottom end. call up AI and get a heads/cam package and hit it with a 150 shot. just make sure your clutch and rear are up to the task
Old Dec 25, 2010 | 01:12 PM
alexcoreas's Avatar
The clutch is definitely not up for the task stupid **** sucks no one should buy an unknown brand lesson learned but I did order my Comp clutch can't wait. And my rear end from what I hear is a POS. I'm looking around for a 12 bolt but I can't find anything under 2k
Can my stock bottom end handle it? I don't want a ticking time bomb.
Old Dec 25, 2010 | 01:14 PM
alexcoreas's Avatar
How much was your kit?
Old Dec 25, 2010 | 01:20 PM
alexcoreas's Avatar
What would have to be done to the bottom end? So it can be reliable?
ill try the search button also she has been my friend too
Old Dec 26, 2010 | 11:41 AM
AChotrod's Avatar
I also have a Nitrous Outlet system. I spray a 150 on top of my H/C/I Lt1 and it make me smile every time I hit it! And yes its cheaper than Boost but can get very expensive also! I prob have almost 2k in my system.
Old Dec 26, 2010 | 12:47 PM
97Z28SS's Avatar
For all you m6 guys do you spraying off the launch or once you're rolling, also what about when you shift, do you have a timer that stops the spray during shifts?
Old Dec 26, 2010 | 12:54 PM
AChotrod's Avatar
I have a progressive controller that has a window switch and a delay to bring on the nitrous depending on how I set it. I also have it wired to my 2 step so When im on the 2 step the nitrous is unarmed as soon as I let off the 2 step the nitrous is armed.
Old Dec 26, 2010 | 11:52 PM
alexcoreas's Avatar
How much horse power are you pushing and TQ? Why 2k did you add extras to the kit
