Im looking to install a Hurricane intake
Old Dec 25, 2010 | 03:03 PM
SPRAYED Z's Avatar
Default Im looking to install a Hurricane intake
its just like the super vic and it will fit lt4 heads which I have. This will be great, nothing extra having to be done and I hope it will bolt to the lt4 head bolt pattern where the intake bolts to?
Either way Im letting everyone know what I got for xmas
Old Dec 25, 2010 | 03:13 PM
defaultexistence's Avatar
liar!
Old Dec 25, 2010 | 03:57 PM
SPRAYED Z's Avatar
lol it was just ordered yesterday from the wife and will be here shortly from summitracing
anyone have a fuel line setup? how bout a elbow?
Old Dec 25, 2010 | 09:12 PM
joelster's Avatar
I run that intake. Mine was modified by a friend of mine, along with a custom elbow setup. Edelbrock makes a good fuel rail for it. It's the one used for the Victor E manifold.
Had to trim the cowl area a little bit here:
Old Dec 25, 2010 | 10:27 PM
SPRAYED Z's Avatar
JOel what r using for fuel lines? Do they connect to the factory fuel lines under the car? HOw did you modify them?
Old Dec 26, 2010 | 06:37 AM
Puck's Avatar
There is an adapter the converts the stock quick-disconnect hard lines to NPT ends..I actually saw some in the FS section a day or two ago.
Old Dec 26, 2010 | 08:07 AM
joelster's Avatar
Just an adapter for a gm fuel line to an type fitting. If you notice where the front of my intake is, my friend chopped off the thermostat area and welded the holes shut which would be used on a sbc application. It is not necessary to do this but it makes the area look a little cleaner. For the elbow he started with a standard 4bbl spacer to use as the base. It has a vacuum fitting on the back of it that we tee'd for the fuel pressure regulator and the brakes.
Old Dec 26, 2010 | 12:01 PM
SPRAYED Z's Avatar
Do you have part numbers on the lines and adapters
I would be greatly appreciated
thanks
Old Dec 26, 2010 | 02:11 PM
joelster's Avatar
thanks
The lines are edelbrock #3630
edelbrock fuel rail stands #3619
no idea on the adapters though
Old Dec 26, 2010 | 02:39 PM
SS RRR's Avatar
Village Troll
So what's your secret to going from 94 to 97mph in the 1/8th?
Old Dec 26, 2010 | 02:50 PM
97Z28SS's Avatar
Quick question the Super Victor and Hurricane intakes are 1" taller than the Vic E is that correct?
Old Dec 26, 2010 | 03:34 PM
Puck's Avatar
Originally Posted by 97Z28SS
Quick question the Super Victor and Hrricane intakes are 1" taller than the Vic E is that correct?
Assuming Hurricane is the same height then yes, since Supervic is 1" higher then Vic Jr.
edit: See post #16
Old Dec 26, 2010 | 06:36 PM
97Z28SS's Avatar
Thanks Puck that means I can add a 1" phlenoic spacer and a ZEX perimiter N20 plate to my setup.
Old Dec 26, 2010 | 08:16 PM
robsquikz28's Avatar
Im told the hurricane is taller than the super vic
Old Dec 26, 2010 | 08:18 PM
joelster's Avatar
94mph was at dunn tire raceway which is a noted "slow" track in warm summer air (+2000da), 97mph was at empire dragway which is typically a tenth faster (to the 1/8th) in much better air.
Old Dec 27, 2010 | 10:58 AM
Puck's Avatar
After a little digging it looks like the Hurricane may be .506" taller then a Supervic, a hair over half an inch.
Would be hard to run a spacer under one in an f-body without some serious cowl cutting.
Old Dec 27, 2010 | 09:42 PM
Thats what I was thinking
Old Dec 27, 2010 | 09:52 PM
97Z28SS's Avatar
I don't have the Hurricane nor the Super Vic, I have the Victor E -EFI intake which is 1.5" shorter than the Hurricane and an inch short than a Super Vic so if I run a 1" spacer and a Zex perimiter N20 plate My setup will be at equal height to the Hurricane intake and I'm running the Nitrous Outlet LT1 elbow for the 58mm tb. Plus my car has a 4" cowl hood.
Old Dec 27, 2010 | 11:57 PM
Puck's Avatar
You will be fine.
The 860 Nitrous Outlet elbow can clear the cowl on a Supervic with minimal trimming, so if you end up 1/2" taller then you may need to do some snipping but nothing too drastic.
Old Dec 28, 2010 | 10:45 AM
97Z28SS's Avatar
Cool Beans, thanks Puck.
