Car back from the mechanic - STILL won't shift while started
The only problem is I can't figure out what he used for that upper part of the rod. It looks like some type of "Thread-All" with a section you can crimp at the end. I've never seen ANYTHING like that though.
Here's the link to the write-up I used https://ls1tech.com/forums/manual-tr...r-writeup.html
Its pretty straight forward and easy to do, only basic tools needed except a 3/8”x16 die.
I'm thinking of splurging on a Tick Adjustable Master Cylinder. Thoughts?
Slapping a new flywheel in couldn't hurt, but it will do little more than ever-so-slightly change the angle of your clutchfork.
You're whole problem is that your hydraulics are incapable of pulling your pressure plate away enough to prevent it from dragging on the friction plate. Since you've already replaced your entire hydraulic system, your hydraulics aren't the problem. A worn out clutchfork can potentially cause your problem, but that's EXTREMELY unlikely.
The problem with your aftermarket clutch, I'm 99% sure, is that the friction plate is slightly thicker than OEM, and because of this your pressure plate needs to be pulled slightly furthur than stock distance to prevent dragging/disengagement problems.
After a thousand or so miles of driving, your friction disk will loose some of its thickness from being compressed under the pressure plate, which might reduce or alleviate your disengagement problem, but until then you'll need to use an adjustable MC to give your clutchfork that extra needed push.
So the most logical solution to this problem would be to buy an adjustable MC or convert your own.
Sorry if it seems like I'm repeating myself man, but this (or replacing everything aftermarket with OEM parts) is the solution to your problem.
the other thing is we put a oem clutch in a 93, the bolt and stand they had holding the clutch fork on was wrong. i cant remember if they forgot the stand or if they had the fork flipped around but when the car started in the air the tires spun all the time.
another idea the clip that the fork uses to pop over the little stand that holds it to the trans if you had a race clutch in it the first time and it bent it due to the extra pressure needed and you put a easier clutch in maybe that could do it?
make sure the fork actually slides over the TOB, i managed to miss it and hook it behind the TOB instead of on it
It still really confuses me that this is happening with two clutch sets and that the Spec had worked fine. It makes me feel like I'm doing something wrong with the installation - but everything goes in extra smooth. The only thing I can even think of is that when you line up the disc and pressure plate - they don't seem to be straight. But the alignment tool easily slides in and out and the transmission slides flush with the bellhousing without needing to use bolts to pull it close.
In fact I know for sure they get updated and changed every so often-- because I was told by a Spec tech guy that the older disks are not interchangeable with the new ones. So there is a tiny chance that if you bought another Spec clutch, you'd run into the same problem as you have with the CC and RAM clutches.
I also find it odd that when you align your clutch upon installation that it doesn't really look lined up. I remember from doing my numerous clutch swaps that if I looked straight though to the pilot bushing, it always lined up perfectly with the friction disk splines, despite the fact that the alignment tool you get is a cheap piece of plastic. Have you thought about getting your hands on an extra T56 input shaft? I've heard of some guys doing that-- using an actual metal input shaft to line things up, instead of the plastic thing.
Oh and in case Tick can't help you with an adjustable MC, I know for sure that McLeod makes one for our cars. The description on their website says its for LS1 f-bodies, however, the LS1 MCs are exactly the same as the LT1s. Its the slaves that are entirely different. McLeod is expensive, but top notch stuff.
I bought a Tick Adjustable Master Cylinder and literally had to adjust it as high as it would go - BUT I CAN SHIFT THROUGH ALL 6 GEARS!
The only problem is I notice the clutch pedal is shaking/wobbling quite a bit. What could this be?
Just drive the car till the clutch break-in period is over and hopefully the shaking will go away. I know my Spec clutch vibrated and wobbled a lot when I'd start driving normally in first gear after I installed it. Its normal, just part of break in process with the organic and kevlar disks.
Where should I look first?
