Car back from the mechanic - STILL won't shift while started
And I guess the mechanic didn't install an adjustable master cylinder. He just extended the rod and pressed it back together. So I'll probably have to take the master cylinder out and do it right, but there's obviously another problem now.
The only thing I can think of that would work would be to make your own adjustable master cylinder (even though extending the rod accomplishes the same thing), you'll need it for it's adjustablilty. Then grind down your fork in the places where its rubbing against the pressure plate, excluding the retainer clip, like SS_RRR did in his picture. Finally grind down clutch fork T, just a little bit off the bottom, like .050" to start.
Grinding the T should pull the clutchfork in far enough that the retainer clip shouldn't rub against the pressure plate anymore.
Grinding the clutch fork will give further clearance between the fork and pressure plate.
Creating an adjustable master cylinder will give you the ability to push your clutchfork as far enough as it needs to fully disengage your clutch.
This isn't a perfect solution to your problem at all, its more or less a way to cheat and get around the problem without solving it. It's also gonna be time consuming, but fortunately its the dead of winter so hopefully you get the car running right by spring.
Good luck man, after this I might be all out of ideas too.
And you are correct. Factory flywheel. And I'm sure it's been resurfaced at least 2-3 times.
Basically I think if you were to go back to the original length on the clutch M/C rod and make doubly sure the fork was pushed in completely onto the TB you would be absolutely fine.
I got the transmission out and discovered the noise was being caused by the inspection cover. It actually broke and part of it was rubbing against the flywheel.
However, the awkward thing is this. Check out how out of line the clutch disc/pressure plate look. Does this look right?:
But the weird thing is the alignment tool slides in and out easily with no resistance either way. This seems weird to me.
Video of the alignment tool:
I'll get the transmission in tomorrow and check.
You will need to change the clutch fork pivot point. Pull the tranny, remove the "t block" that the fork pivots on and grind the base of it .100" or so and then re install. I think the paper work that comes with the ram clutches may say something about this.
