adding power windows and locks
Old Jan 20, 2011 | 09:04 PM
  #41
Chaotic94's Avatar
Well I'm not sure. I haven't ripped into my door yet. I know that the new door has power windows and locks though. Where should I look to see if I have the wiring?
Old Jan 20, 2011 | 09:20 PM
  #42
fex77k's Avatar
In the forward part of the car door.
Old Jan 20, 2011 | 09:25 PM
  #43
Chaotic94's Avatar
What about under the kick panel?
Old Jan 20, 2011 | 10:52 PM
  #44
z28cam1970's Avatar
i have a non power window and power lock car and when i put new speakers in the car i noticed the wiring is already there for the power windows and locks the connectors are taped on harness you will need the window motor, regulator and switches (drivers and pass) for windows and latches and switches for door locks also you will need to put fuses in fuse box for both fuse box cover gives you fuse location works the same for power seat as well
Old Jan 20, 2011 | 11:47 PM
  #45
Chaotic94's Avatar
You, sir, just made my freakin' day! Thank you for a straight forward answer. "YES, the wiring is there" Saweet!!! What year is your car? I would assume 1970 from your user name but do you also have a 4th gen?
