Experts come in and help
Old Jan 1, 2011 | 01:30 PM
Lgoldtop's Avatar
Default Experts come in and help
okay, so let me start by staying I HAVE NO IDEA HOW THIS HAPPENED. I was putting on the harmonic balancer and was tourqeing it to specs when it snapped. now what i need help on is HOW TO GET THE DARN THING OFF SO I CAN REPLACE IT. And please save all the negative feedback for yourself. i already feel like an idiot for having it happen. just help me dont dis me and make me look even worse thanks alot.
Old Jan 1, 2011 | 01:53 PM
RamAir95TA's Avatar
What probably happened at some point is someone tried removing the hub with a center bolt that was too large, pressing against the hub instead of the crank snout. This could weaken and/or break the ears clean off.
What I would do is weld the ear back on, then use the right hub removal tool.
Old Jan 1, 2011 | 02:06 PM
Lgoldtop's Avatar
Thats a really good idea and i appreciate you not "hazing" me. Granted im only 20 years old and I built my 383 with my dad i still have alot of knowledge to aquire. never the less, would that be safe to do? in my pic,in case you didnt notice, i have the Gen 5 Dynaspark distributor that works directly with my Delteq setup. Would the heat affect any seals around the oil pain? and should i mig weld it or tig it?
Old Jan 1, 2011 | 02:22 PM
RamAir95TA's Avatar
As long as you're easy with the heat I wouldn't worry about it too much. That's a pretty thick piece of metal so the heat shouldn't travel too far. You also won't need to weld the crap out of it - a few solid beads is all you need. Remember you just need enough material to hold it on while you use the puller. MIG would be fine. Keep in mind the puller will evenly distribute the load over all THREE tabs.
When you have the hub off, I would go ahead and replace the seal since you're there, and if the heat does travel that far it will melt/distort the rubber.
Old Jan 1, 2011 | 02:29 PM
Lgoldtop's Avatar
alright. thanks man i really appreciate. if you have any other tips or what not let me know-Jordan
Old Jan 1, 2011 | 02:37 PM
96capricemgr's Avatar
I don't know how well that material would weld.
What about using a grinding wheel and grinding some reliefs in it to get a three jaw puller on it??
