AI 385 LT1 Motor Re-Build Thread....PICS/VIDEO!!!
#222
Update....wiring!!!!!!!
Well I havent updated in a week or so..........been wiring......wiring and still wiring........i got the XFI finally wired in and got everything pretty much back together....i just gotta clean everything up now and make it neater....power windows, door locks, gauges and all interior lights still work along with the wipers and the retained power accessory module after the key is off........also lost another 60lbs of crap between the passangers air bag......abs and air bag control modules.......extra wiring and the door support bars (dont need em with a 10 pt cage)........also got the headers and custom billet aluminum plates i made ported and bolted up.........and got the wiring harness and radiator and pretty much everything else back together as well..........currently im just waiting on some steering shaft stuff from borgeson because apparently hedman didn't worry too much about steering when they made these headers lol........should hopefully fire it up this weekend........pics below....
#231
well its kinda starting to look like a car again...........wiring is done carpet is in......xfi is in.....msd box is in........just gotta pull the drivers side header and do a little mod on it damn #5 plug doesnt fit .....
gonna eventually put some new speed inc lightweight carpet in it but i just dont want to throw $300 at it right now......save it for another day
#233
[QUOTE=quik95lt1;14706360]well i finally got the relay/fuse center complete for under the dash..........used a piece of lexan to mount everything to.......came out good.......now just gotta get it in the car and plug everything in.......run my power wires and finish up a few things and I'll be good to go............weather this weekend is looking like trash except for sunday......maybe I can get it fired then........heres a few pics of the wiring.........
i cleaned up the bmr block off plate too.......did it like all my other brackets and clear coated it.......made a little lexan plate too for it to cover up some old existing holes....
Very nice job on the wiring! You need to get one of the small label printers from Office depot. All of my wiring boards that I make use that print system. It makes for a finished product look. Your engine bay is really starting to look amazing !!
#235
well i ran into a little issue this weekend..........i got the car back together......the interior is in and pretty much everything is done but i couldn't get the steering to work properly...........soooo solution is......we are gonna chop the #1 header primary off and remake it to go around the steering shaft......problem solved.......doing that tomorrow night so should hopefully be running later this week..........heres a few pics of the interior and stuff comming togheter...
#237
nah i got the stock steering staft and rack but the #1 primary was like directly in the way of the shaft......so i bought a bunch of borgeson u joints and crap to try and go around it but it kept binding on me.........its easier to just move the header pipe instead
#238
Yep, thats the same issue I had with mine. I bought a couple joints from Flaming River, and went around it...but I didn't like how it felt. It had a bind in it, so we cut the #1 primary down and fabbed up a new one. Made it go around the shaft' and it looks just fine
