who makes an ABS delete block for LT1 cars?
There isn't much to write up really. The front lines use 3/16" line and use standard double flares, while the rear uses one single 1/4" line.
For the fronts:
Master cylinder --> tee --> to front calipers.
Or if you have a line lock...
Master cylinder --> line lock --> tee --> to front calipers.
The rear is easy...
Master cylinder --> proportioning valve --> rear line.
If you draw it out you can figure out how many fittings you'll need.
For the fronts:
The rear is easy...
Does anyone have pics of their home made kits? What parts do I need to get from the auto parts store to make this happen?
I bought a distribution block/proportioning valve from Jegs and it was a pain in the *** to install. I hope I NEVER have to do it again...http://www.jegs.com/p/JEGS-Performan...62853/10002/-1 But the end results were worth it.
I took the line for the rear bent it up and directly into the master, then took the line for the front and just a tee in between. I think it cost less than $10 for fittings. You don't need to buy any line.
Yeah I wish I hadn't bought a kit, my motor guy laughed when he helped me do my ABS delete as he had a really nice flaring tool. All I really ended up using from the kit was the distribution block for the front and the proportioning valve. I could have saved about half what I spent.
