Lt1 383 build help
. I was ignorant, and probably still am in some areas, but how else do you learn? Feel free to use me as a "classic example". I didn't just pick up random parts, though. I picked out my cam and took the advice of the engine parts guys and my uncle. The heads are just ported stock. We were thinking about 320rwhp, but you might be right, maybe lower. I've done a lot to support the motor since my last trip to the track, so we'll see what happens next time at the track.
. I was ignorant, and probably still am in some areas, but how else do you learn? Feel free to use me as a "classic example". I didn't just pick up random parts, though. I picked out my cam and took the advice of the engine parts guys and my uncle. The heads are just ported stock. We were thinking about 320rwhp, but you might be right, maybe lower. I've done a lot to support the motor since my last trip to the track, so we'll see what happens next time at the track.And what else you have done to help them
numbers
. I was ignorant, and probably still am in some areas, but how else do you learn? Feel free to use me as a "classic example". I didn't just pick up random parts, though. I picked out my cam and took the advice of the engine parts guys and my uncle. The heads are just ported stock. We were thinking about 320rwhp, but you might be right, maybe lower. I've done a lot to support the motor since my last trip to the track, so we'll see what happens next time at the track.Sure hands-on experience helps in actually BUILDING IT of course, but deciding on and acquiring the parts that WORK is just as important.
Since my last trip, I've had Solomon tune done, msd wires, gone from 225/60/16 walmart tires to 295/35/18 BFG KDW2 (no, not as sticky as a drag radial, but I needed something to last longer), electric cutout, posi carrier (only spinning one tire last time out), I'm getting a wide-band O2 in the mail tomorrow to really fine tune, i've gotten rid of annoying knock problems. I still need to get bigger injectors and probably a few other things.
It seems like the motor is not making power past 5k rpms for some reason. Last time at the track I changed shift points from 5800 to 5500 to 5200 and finally 5000, which seemed to be the best shift point based on my ET's. This may have been corrected with the tune.
And lastly, my heads weren't CNC ported or anything. It was done at my uncles shop. I don't know the technical lingo, but I watched and helped throughout the whole process. He has a few tricks to getting heads to open up and the valves to seat better. Nothing compared to a CNC port job I'm sure.
