Getting frustrated
Old Jan 5, 2011 | 11:31 AM
skittle's Avatar
Default Getting frustrated
Ok heres the dealeo
The car is a 1976 Datsun 280Z
Engine - 94 LT1 w/ sanderson block hugger headers
Tranny - 89 WC T-5
Electronics - 93 PCM (eprom chip) with standalone harness (both for a b-body)
Jet performance Stage 2 chip
For some reason I am not getting the injectors to fire.
I have 44psi of fuel, opti works fine (will run all day on starter fluid)
Vats was supposed to be removed from the chip as well as smog stuff.
I bought a VATS bypass module just in case.
Checked injectors and they work fine if I connect with a pigtail to the battery
used a noid light and no lights what so ever. Ohmed out the connectors and I'm getting 12v to the injectors just no ground.
I'm almost at wits end with this and I dont really want to take it to a shop.
any help would be great
Thanks!
Old Jan 5, 2011 | 12:33 PM
RamAir95TA's Avatar
Make sure the PCM is grounded properly (small black wire, pin C32). If you confirm it's grounded, scan the PCM for any codes (if possible).
Old Jan 5, 2011 | 12:40 PM
skittle's Avatar
nope no scanner, what connector is the ground wire supposed to be on? My harness only has 1 big ground wire in it.
Old Jan 5, 2011 | 12:44 PM
RamAir95TA's Avatar
I posted it in my thread...C32.
Old Jan 5, 2011 | 01:43 PM
lt1-xjs's Avatar
Pull the Jet chip and run on the stock one, install the vats bypass.
Old Jan 5, 2011 | 06:07 PM
skittle's Avatar
did not come with the stock chip, do you happen to know what color the connector is for c32?
Old Jan 5, 2011 | 06:18 PM
RamAir95TA's Avatar
On the PCM, there are four big connectors. C is gray/clear (pretty sure it's all labeled too).
I would also ditch the Jet Chip...sometimes they do more harm than good.
Old Jan 5, 2011 | 06:30 PM
skittle's Avatar
Yeah I'll get a chip reburned with emmissions a/c ect deleted. Unless of course If I could sell the 93 ecu with harness and get a new harness for my 94 ecu...
Old Jan 5, 2011 | 06:32 PM
RamAir95TA's Avatar
If you have the option of ditching the 93 PCM, I would DEFINITELY jump on that. Keep in mind thought that you'll need to pick up a MAF too (or have it tuned out).
Old Jan 5, 2011 | 09:33 PM
skittle's Avatar
Yeah I would prefer the 94... I'll see what i can get for the harness and ecu
