EWP time?
Old Jan 6, 2011 | 10:50 PM
Z28 boy's Avatar
Default EWP time?
i need some guidance on whether or not to change to an electric water pump. the car has a rebuilt 355, exhaust, and stuff... it runs cool on the highway and during spirited driving with a stock T-stat, but in town its over 210,215 every time i pull up to a light, sometimes hotter. im thinking about a 160 t-stat too.
should i just put a 160 t-stat in it and call it good? the car gets driven every day too. im kinda worried about the reliability of the EWP.
any recomendations on a brand of pump?
Old Jan 6, 2011 | 10:51 PM
transamws6_97's Avatar
Theyre rated for 2500 hours which if you drive an hour everyday is over 6 years. I got a meziere
Old Jan 6, 2011 | 10:54 PM
Z28 boy's Avatar
Thats way better than i thought it was. Ill look into those a little bit more then. should i get a 160 too?
Old Jan 6, 2011 | 11:00 PM
RamAir95TA's Avatar
The 160-stat won't do you much good in hot weather without reprogrammed PCM operation.
I see you have a hotcam...assuming you have tuning already you can just ask for a reflash.
And I wouldn't worry about the reliability of the EWPs. I've been on mine for 6 years now and I'm pretty sure one of the Impala guys has been running the same one for 8ish.
Old Jan 7, 2011 | 01:48 AM
MasterTomos's Avatar
^Which brand are you running?
Old Jan 7, 2011 | 03:00 AM
RamAir95TA's Avatar
I'm running the CSI pump (now CSR).
Old Jan 7, 2011 | 05:19 AM
hitmanws6's Avatar
I have the CSI pump as well, works great
Old Jan 7, 2011 | 07:34 AM
quik95lt1's Avatar
been running a miezerre for 4 years here no issues at all.....
Old Jan 7, 2011 | 07:56 AM
Formula WS6's Avatar
I've been running a CSI for 6 years now without one hiccup.
Old Jan 7, 2011 | 07:57 AM
mguidry629's Avatar
Isn't 210-215 normal running temperature? IIRC, my stock tune had the 1st fan coming on around 215-220, so aren't these cars designed to run somewhere around that area?
Old Jan 7, 2011 | 08:02 AM
quik95lt1's Avatar
^ yep
Old Jan 10, 2011 | 07:41 AM
Z28 boy's Avatar
PMC has been tuned. The fans kick-on temps have been adjusted a lil bit already. Thanks for all the advice guys. I didnt really want to drop the coin in an EWP just yet anyway. ill get a 160 t-stat and go from there. Im tired of this thing running hot at stop lights and city driving.
Old Jan 10, 2011 | 11:11 AM
AChotrod's Avatar
Mez here with 0 issues and the car runs super cool with a tune and 160 stat.
Old Jan 10, 2011 | 01:53 PM
Z28 boy's Avatar
Gonna order one today probably!! Thanks guys
Z28 boy's Avatar
Thermostat that is^
