High flow cats
Old Jan 8, 2011 | 09:05 PM
BlackBird87's Avatar
Default High flow cats
So im turning into an old man and the fuel smell is starting to get to me. So im looking into hi flow cats to put on and i need suggestions on what brand to go with and should i run two inline with each other
Old Jan 8, 2011 | 09:27 PM
David94TA's Avatar
Right there with you turning into an old man. I have these on my car:
http://www.magnaflow.com/02catalytic...versal/595.asp
They came in my Kooks y-pipe. Work great and pass emissions easily.
Old Jan 8, 2011 | 09:35 PM
Are you running one or two.
Old Jan 8, 2011 | 09:55 PM
speed_demon24's Avatar
If you are running a decent size cam forget about cats. All they did to my car was turn the raw fuel smell into the horrid rotten egg smell.
Old Jan 8, 2011 | 10:17 PM
Its basically a 503 cam.
Old Jan 8, 2011 | 10:18 PM
hitmanws6's Avatar
I like metallic core cats. Magnaflows part number is 59559 I believe, the Thunderbolt metallic ones are the same thing
Old Jan 9, 2011 | 01:41 AM
LVZ2881's Avatar
Summit has the metallic spun cats like in the link above for $93.15.
I'm picking one up tomorrow
Old Jan 9, 2011 | 02:09 AM
96azz28's Avatar
I have a pair of pypes cats if your interested
Old Jan 9, 2011 | 09:22 AM
David94TA's Avatar
Two--one on each side of the Y-pipe
Old Jan 9, 2011 | 10:47 AM
DAVE00's Avatar
I have a single 3 in/out magnaflow hi flo cat on my custom y with a very large custom cam from LE and have zero rotten egg smell. However, I don't DD the car and I've been told with the overlap on my cam this cat wouldn't last long in a daily due to the fuel burning off in the cat greatly shortening it's life. It's not a big deal for me as I put very little miles on her yearly.
Old Jan 9, 2011 | 11:08 AM
Drak03's Avatar
DAVE00 is right. you better research how long the cat you buy is gonna last you or your gonna end up buying new a lot if you DD that car
Old Jan 9, 2011 | 11:38 AM
The car is not my DD. Im gonna tweak the tune a lil bit cuz i think its too rich as it is but im not to worried about killing cats early. Looks like magnaflow is gonna be the one to go with now i have to figure out one or two and where i can put them. I have room where the hump in the floor is but i dont think thats close enough to the headers
Old Jan 9, 2011 | 03:23 PM
spudnick3119's Avatar
I have two cats on my car, one on each side of the y-pipe. I have the Thunderbolt metallic cats and they are probably one of the smaller cats available. I'm lowered about 1.3" and initially I scraped them the first few months, but now they seem to be good.
I'm running a fairly large cam and I don't get any smells, just a little bit on startup when its cold. Car sounds good and runs well, I have no complaints with them. I will be taking them off this year however, I have an extra y-pipe and want to see how it sounds with no cats on the car.
Edit: I noticed you have Edelbrock shorties. My dad's car has SLP shorties and has two small Random Tech cats in the y-pipe, so you should be able to get away with two.
Old Jan 9, 2011 | 03:37 PM
Hmm i do like how small those are and pretty cheap too.
