adjusting pinion angle
Old Jan 14, 2011 | 11:24 AM
stangkiller2005's Avatar
Default adjusting pinion angle
On a lowered car is the pinion angle still suppose to be set at negative 2? With sphon adjustable TA and driveshaft loop? Also what is the correct way to calculate the pinion angle? Thank you.
Old Jan 14, 2011 | 11:31 AM
I have a magnetic protractor thing from home depot. I think it should do the job.
Old Jan 14, 2011 | 12:09 PM
No insight?
Old Jan 14, 2011 | 12:47 PM
lethal bird's Avatar
Yea thats right -2 for a street car.
Old Jan 14, 2011 | 12:48 PM
DAVE00's Avatar
Yes - -1.5 to -2 is where you want to be. That is what the rep from BMR told me directly a few days ago when I was readjusting mine. I also sit on Eibach pro springs and have all updated suspension parts.
Old Jan 14, 2011 | 12:52 PM
Awesome. Thanks guys! So I know that i need to subtract one number from the other to get negative two. Is that correct? I forgot witch two things I need to messure. I just know one is at the bottom of the torque arm.
Old Jan 14, 2011 | 12:55 PM
DAVE00's Avatar
Also, here is a great video to help you out calculating the right angle:
http://www.youtube.com/watch?v=UAQgLbhQ0uk
Old Jan 14, 2011 | 12:56 PM
DAVE00's Avatar
See the video. Good luck.
Old Jan 14, 2011 | 04:54 PM
WhistlingZ's Avatar
Bottom of the rear end pumpkin and drive shaft.
Old Jan 14, 2011 | 04:58 PM
gregrob's Avatar
Nope.
Old Jan 14, 2011 | 05:03 PM
97Z28SS's Avatar
Great video, very helpful.
Old Jan 14, 2011 | 05:20 PM
MYSTIC-1SC's Avatar
Definetly a good video for people unsure of how to set the pinion angle on their torque arm.
Old Jan 14, 2011 | 06:16 PM
SS RRR's Avatar
Village Troll
I've never had luck with the plastic angle finders. It was never accurate. I bought a digital one from Sears and it is far more user friendly. I've had the best luck by adjusting both the drive shaft and diff to the same angle so both are are at a straight line and then backing off the diff -2*.
Old Jan 14, 2011 | 08:39 PM
DAVE00's Avatar
Watch the video and learn and NO.
Old Jan 14, 2011 | 08:46 PM
thanks for the vid. i think i got it pretty close. is there anyway to know if its really off or well adjusted? drove car. seems to be fine...
Old Jan 14, 2011 | 08:59 PM
WhistlingZ's Avatar
Well I stand corrected.
Old Jan 15, 2011 | 12:00 AM
gregrob's Avatar
Crank angle is what should be used. EVERYONE says to use the everyone angle though, even seen it in magazines that way.
Crank angle is the right way though. Drive line works in most cases though
Old Jan 15, 2011 | 04:25 PM
vtec's Avatar
Resident Racing Jerk
i checked a car that was setup by the "everyone" angle... basically the car was parked on level ground and angle finder was stuck to the bottom of the torque arm mount and set for -3 degrees. for the last 4-5 years the car vibrated, broke a pinion support, and never launched right.
i checked it and got somewhere around -14 or -17 degrees, i cant remember now.
one of the biggest names in the 4th gen chassis world made a post several years ago telling people to use the "level ground" method. i couldnt believe it. that guy builds chassis and tunes 7 second cars now. lol...
Old Jan 15, 2011 | 04:48 PM
gregrob's Avatar
Lol
Old Jan 15, 2011 | 05:14 PM
wrd1972's Avatar
I saw that too and thought WTF.
