lt1 overheating
Old Jan 25, 2011 | 05:48 PM
coolmanvette75's Avatar
if its leaking under the battery then the cross over tube to the overflow has a leak. im gonna subscribe to this. im having a similar problem. the car has a slow leak when i turn it on. it overheated the other day and was blowing steam out of the rad. cap. i cant figure out where the leak is coming from though. im taking it to school tomorrow and putting it up on the lift. ill let you know what i find.
btw, it the new t-stat you put in the lt1 specific long thermostat? because of the reverse flow, regular sbc t-stats wont work right.
Old Jan 26, 2011 | 03:43 AM
BLACK 97 SS's Avatar
Actually Im gonna check the thermostat again because I don't remember....but let me know how it goes with your car
Old Jan 26, 2011 | 03:57 AM
onephatZ28's Avatar
+2 check the radiator cap
Old Jan 26, 2011 | 02:33 PM
no steam came out of the radiator cap...i was driving the car for like 45 min and all of a sudden it started to get real hot so i just shut it off and opened the hood but did not see steam...im also gonna check the steam pipe again
Old Jan 26, 2011 | 02:48 PM
well it seems like i have bigger problems. my radiator core is busted. i think the t-stat got stuck closed, causing it to bust. time for a new rad. luckily they only run like 100 bucks. gonna throw in a 160 t-stat while im at it
Old Jan 26, 2011 | 03:19 PM
i will have to check my radiator core as well as my thermostat
Old Jan 26, 2011 | 03:23 PM
yea i put it on the lift and after a min. of running, it looked like it was raining under my car. lol
Old Jan 27, 2011 | 01:34 PM
WELL I DROVE for a lil while today its doing the same thing but there was no leaking....im leaning a lil more toward the thermostat im gonna check it this weekend and it smells like gas really bad inside the car
Old Jan 27, 2011 | 02:18 PM
SS#502's Avatar
Check your sparkplug on the driverside closest to your firewall #8 cyl. Mine always backs out for some reason and smells horrible in the car...
Old Jan 27, 2011 | 03:18 PM
well it does smell horrible and it is running rich...ill have to take a look
Old Jan 27, 2011 | 04:01 PM
93M6Formula's Avatar
Definately check the T-stat, my formula kept doing the exact same thing when I first got it. It would get super hot even with the fans on. Then finally i put a new 160 stat in there and fixed it right up!
Good luck!
Old Jan 28, 2011 | 03:29 AM
  #32
How hot would your temp. Get ?
Old Feb 23, 2011 | 02:32 PM
  #33
ok so after finally having some time i saw that one of my fans is not coming on..why would this be? sorry for all these questions but im a total newbie
Old Feb 23, 2011 | 03:41 PM
  #34
onephatZ28's Avatar
you may have a bad relay, pull it out and make a jump wire and jump it and see if it come on, if the fan come on it a bad relay
also turn your A/C on then look and see if your fans are, on they should turn on when you turn the a/c on
Old Feb 24, 2011 | 02:45 PM
  #35
when i turned on my ac i heard a click and then it does it every 3-5 seconds..is that normal?
Old Feb 24, 2011 | 02:54 PM
  #36
WS Sick's Avatar
Probably your AC compressor kicking on and off.
