lt1 overheating
Old Jan 16, 2011 | 02:13 PM
BLACK 97 SS's Avatar
Default lt1 overheating
so i replaced my head gaskets,new coolant temp sensors,coolant flush,bled the system but car is still overheating when being driven for about 20 min...might i add it has a new thermostat
Old Jan 16, 2011 | 02:15 PM
tbird31's Avatar
are the fans kicking on?
Old Jan 16, 2011 | 02:16 PM
mikeyc34's Avatar
did you check the waterpump. i had a jeep that wouldnt blow hot air in the winter and since i didnt drive it very far never overheated until one day i drove it an hour away and it overheated and threw a rod bearing. just a thought. and why did you replace the head gaskets? were they leaking?
Old Jan 16, 2011 | 02:44 PM
i forgot to add i have a new water pump and the fans are kicking on also...my gauge went all the way to the red and i shut off my car and minutes later i went back outside and saw that it leaked coolant...maybe my radiator
Old Jan 16, 2011 | 04:24 PM
96azz28's Avatar
Check your radiator and your hoses, its probably time for a new one.
I had a similar problem and one night my radiator took a **** so i got it fixed, it wasnt that hard to replace
Old Jan 16, 2011 | 05:26 PM
formula vincent's Avatar
check radiator and thermostat.
Old Jan 17, 2011 | 03:08 AM
SS#502's Avatar
Make sure the coolant overflow tank line and the coolant steam lines that go to the heads aren't mixed up, you'll overheat really quick...
Old Jan 17, 2011 | 01:15 PM
thanks for all the help...the leaking is coming from the overflow so ill check all lines again
Old Jan 17, 2011 | 02:41 PM
its starts to sound like boiling and the leaking starts once the car is at 220 and after that it starts to heat up quick
Old Jan 17, 2011 | 05:29 PM
SS#502's Avatar
Sounds like you bled the system wrong, when bled it, did you open both the steam pipe line and the little one from the thermostat? If you opened up the steampipe line then the heads won't be able to breath. I had the same problem awhile ago and once I bled it the proper way it has been great ever since. There are a couple of overheating issue threads on here that have the whole breakdown of how to do it. Even with my fans on it would overheat and I ended up blowing out my Driverside headgasket, I found out the hardway!
Old Jan 17, 2011 | 09:57 PM
BigD383lt1's Avatar
It sounds silly but is it the original radiator cap? if the cap doesn't seal properly it will flow back into the over flow. Also did you put the return and the overflow on correctly over flow should go to the top and the return just under it... Very easy to switch!
Old Jan 18, 2011 | 12:43 AM
myk's Avatar
myk
I'd test that new t-stat...
Old Jan 18, 2011 | 02:25 AM
SS RRR's Avatar
Village Troll
My guesses are the coolant return line and reservoir hoses are mixed up and/or the waterpump coupler to the splined w/p driveshaft is missing...
Old Jan 20, 2011 | 01:21 PM
well i havent really did anymore checking on my car but this morning i put a lil coolant in the reservoir without the car being on and it started to leak a lil at the bottom by where the battery is ill take a better look at it on the weekend when i have more time
Old Jan 20, 2011 | 02:22 PM
69gto96z's Avatar
+1 on this. I had the same problem after putting a new radiator in about 6 years ago. The hose to the overflow should be the top hose coming off the radiator. If yours is boiling out of the overflow, I would be willing to bet this is your culprit, because that is what mine did,
Old Jan 20, 2011 | 03:28 PM
thanks alot for all of your input hopefully i can fix my problem this weekend
Old Jan 22, 2011 | 06:11 PM
Well my fans are not turning on...even with the heater on
Old Jan 24, 2011 | 10:32 AM
correction to that the relay was not on right...well i bled the system again and it still had some air....but as i was driving it for like 45 min my check engine light came on and car started to get hot again the codes it gave me are p0172 and p0175
Old Jan 24, 2011 | 10:19 PM
69gto96z's Avatar
Those are odd codes to be throwing if you are overheating. Did the car feel like it was stumbling from having too much fuel?
Old Jan 25, 2011 | 03:19 AM
Kind of and it starting to smell like fuel.....maybe injectors?
