Cam
Old Feb 10, 2004 | 10:59 PM
MA1384's Avatar
Default Cam
Can anyone tell me what kind of cam i should get, like what lift and duration is best, and what brand name. Also what kind of power gains id be seeing from this.
Thanks.
Old Feb 10, 2004 | 11:27 PM
TSAEB's Avatar
in case no one helps you just contact comp cam(1-800-999-0853 i think)...they will huck u up
Old Feb 11, 2004 | 02:43 AM
*High-Noon*'s Avatar
If those are all your mods, I would definately do some more bolt on's before the cam.
Old Feb 11, 2004 | 08:06 PM
MA1384's Avatar
Oh yea, a cam is only a small part, hooker long tubes, cai among others are also commin.
Old Feb 11, 2004 | 08:08 PM
Vendetta's Avatar
if you want the most power for a hyd roller, do a Comp 306 with 1.6 roller rockers
Old Feb 11, 2004 | 09:22 PM
OneMeanZ's Avatar
Old Feb 11, 2004 | 10:19 PM
Vendetta's Avatar
Note- comp 306 is 230/244 .510/.540 112LSA i believe
Old Feb 12, 2004 | 08:15 AM
MA1384's Avatar
roughly what kind of power will i see from this?
Old Feb 12, 2004 | 11:45 AM
Elysian's Avatar
How high will a 306 with 1.6rr rev? Above 7000 or not?
Old Feb 12, 2004 | 01:36 PM
Vendetta's Avatar
A lot if you've got full exhaust, even more if you've got worked heads.
Old Feb 12, 2004 | 11:21 PM
HOOZNXT's Avatar
If I were you I'd go with a Comp Cams XE Grind. Take a look at this link. You'll find something alot closer to what you want then just going with a CC306. Give these guys a call I've heard nothing but good thing about them. I believe you can get a kit (1.6 pro mag rollers, valve springs good to 600 lift, cam) anway here is the link. Take your pick.
http://www.cmotorsports.com/engine/l...ft-design.html
Old Feb 17, 2004 | 07:49 AM
642642's Avatar
I have a brand new set (never installed) of the CMotorsports that my girl bought me that Im going to be selling. (I have a LS1 so I cant use them)
CM-612 Valve springs (fit stock head without machining) good to .600” lift
Ultra Lightweight Chromoly Valve Spring Retainers
Hardened valve locks
Im looking to get 285 plus shipping for them.
Old Feb 17, 2004 | 08:21 AM
OneMeanZ's Avatar
If I have a stock motor, then get LTs, CAI, Comp 306 and heads that have been worked on, what power are we talking about here, like 330 or so? or more?
Old Feb 17, 2004 | 12:28 PM
94Formula/TA's Avatar
One of my friends has 405rwhp off stage II heads with a port matched intake and the usual bolt ons intake and exhaust. Plus a nice dyno tune, it's very possible with the 306 cam he did it.
