Opti problems
You probably broke the opti then if it was not the original problem.
Can you learn how to describe things?
Is the starter turning the engine over??
If it is turning over, is it attempting to fire?
Have you checked for spark and fuel pressure?
The opti is a good piece, ignorant owners is the single biggest problem it has, sounds like you blindly bought into all the internet bullshit about how bad it is and because of such have made no coherent attempt at diagnosis.
There are lots of walk thru pics on here and all over the 'net.
Its also possible to break the opti if the installed incorrectly.
So, take a step back and look at the parts, and get the opti installed with the correct alignment. Also trace out the plug wires and match them to the numbers molded into the opti cap.
Bob
...learned something new today
