winter mods
Old Jan 26, 2011 | 11:45 AM
irocurpony8489's Avatar
Default winter mods
Looking to see what else i can do that doesnt involve heads and cam to cut off some et. mods in signature.
Old Jan 26, 2011 | 11:49 AM
bigj2717's Avatar
Suspension, roller rockers, and remove weight
Old Jan 26, 2011 | 12:03 PM
suspension wise i got tubular lca non adjustable car cuts a 1.70 ran a 12.88. What kind of weight mods can i do without tearing the car apart?
Old Jan 26, 2011 | 12:04 PM
Lawhead's Avatar
Do the LS1 lid swap.
You won't be disappointed
Old Jan 26, 2011 | 02:04 PM
BlackBird87's Avatar
Thats a pretty good 60'
Old Jan 26, 2011 | 02:47 PM
other then rr, up, and ewp what else bolt on wise. Do you need a cowl induction to run a lid?
Old Jan 26, 2011 | 02:49 PM
Lawhead's Avatar
I don't think So I did it on the T/A not the camaro maybe someone will chime in I have to cut some of my front support for the fliter to lay into and the under side of my hood a lil but going with a Ram Air hood soon so it will fit under that.
Old Jan 26, 2011 | 04:22 PM
lt1-xjs's Avatar
1.7's with beehives, CSR pump, ASP 945103 set, LS1 lid mod and an X pipe. Should put you sub 12.5, then put it on a diet.
Old Jan 27, 2011 | 11:35 AM
who makes 1.7 roller rockers? I was looking at the 918 beehives do you have to buy new lock and retainers and if so what kind?
Old Jan 27, 2011 | 12:43 PM
lt1-xjs's Avatar
Scorpion scp 1026, comp 26918's, comp 787-16 retainer, stock seat and stock locks. For running the stock cam.
Old Jan 27, 2011 | 02:04 PM
do you have to pull the timing cover off and removing something to get the benefits of the electric wp? or do you just instal the electric motor in the stock water pump and been done with it?
