Replacing opti, do water pump at same time?
Old Feb 1, 2011 | 03:06 PM
wickedbusa's Avatar
Default Replacing opti, do water pump at same time?
Hey everyone,
My opti is getting replaced this weekend. For you guys that have gone through the painful process, did you replace your water pump while you were at it? My car has 83xxx miles. I don't have any water pump leaks or anything, and I think the water pump may be original. Should I just go ahead and replace the water pump at the same time? Anyone know what the life expectancy on an LT1 water pump is?
Old Feb 1, 2011 | 03:12 PM
jaycenk's Avatar
I would. No point in skipping it unless it has under 50k on it.
Old Feb 1, 2011 | 03:21 PM
djjab57's Avatar
YESS ! Your already there might as well
Old Feb 1, 2011 | 03:28 PM
speedracer2536's Avatar
perfect opportunity to go electric
Old Feb 1, 2011 | 03:39 PM
lethal bird's Avatar
Yep go head and do it. I would be stupid not to.
Old Feb 1, 2011 | 03:51 PM
onephatZ28's Avatar
yes, i would too
Old Feb 1, 2011 | 03:55 PM
qc97z's Avatar
Yes. Replace it.
Old Feb 1, 2011 | 03:58 PM
defaultexistence's Avatar
If it is in fact the original then,Agreed ...Yes
Old Feb 1, 2011 | 04:04 PM
wickedbusa's Avatar
Would there be any benefits to moving to an electrical pump?
Old Feb 1, 2011 | 04:06 PM
whytryz28's Avatar
I replaced my Opti 3 times and my 200k mileage water pump is still going strong.
If it aint broke, dont fix it.
Old Feb 1, 2011 | 05:20 PM
93M6Formula's Avatar
Since the LT1 waterpump is gear driven off of the cam, you can pick up a little power from using an electric pump. But if you do so, I would recomend removing the gear from inside the timing cover so it's not just spinning in there doing nothing and potentially taking wobbling around.
Old Feb 1, 2011 | 05:21 PM
This^, if the the bearing on the back of the pump looks fine and it wasn't leaking, i wouldn't see any reason to replace it. they're aren't hard to replace if they go bad anyway.
Old Feb 1, 2011 | 07:18 PM
MasterTomos's Avatar
At the very least, go to a dealership and get new o-rings for the water pump. Replace it if you can afford it.
Old Feb 1, 2011 | 07:35 PM
wickedbusa's Avatar
Thanks for the advice. I'll examine the water pump when it comes out and go from there. If it's still ok and not leaking, I might just keep it in there and save the money. If it ever does leak and go out, won't my opti be the first to go since it sits right under the pump?
Old Feb 1, 2011 | 07:45 PM
wysemunky's Avatar
I replaced my working factory waterpump with a parts store reman unit because i figured might as well since i had it off anyway. It left me on the side of the road 100 miles from home at midnight.
Old Feb 1, 2011 | 08:47 PM
whytryz28's Avatar
I trust my high mileage pump over some remanned chinese piece of **** anyday.
Old Feb 1, 2011 | 08:59 PM
byatescmco's Avatar
X2 love my electric
Old Feb 1, 2011 | 09:04 PM
RamAir95TA's Avatar
Electric +1.
Leaving the stock 83k pump +1.
Either one is your best bet. I see no need to change the pump.
Old Feb 1, 2011 | 09:35 PM
l 95 Trans Am l's Avatar
If the bearing in the waterpump doesn't have any play then i wouldn't.
Old Feb 1, 2011 | 10:50 PM
Big Bad Bud's Avatar
Replace the pump. Go electric.
