OBDII to OBDI conversion
Old Feb 3, 2011 | 09:30 PM
  #41
SS RRR's Avatar
Village Troll
Originally Posted by LSWHO
I know that's all his conversion is. I was talking more price point vs. work as opposed to what his conversion does or doesn't necessitate.
I dunno... Perhaps an e-mail to Ion is in order? I can't do it all!
Old Feb 3, 2011 | 09:44 PM
  #42
mguidry629's Avatar
So everyone is saying you can just switch the pcm and knock sensor, but what about the difference in the connectors which I posted earlier? Some of the power feeds from the PCM to fuses are in different locations. If yall say it works, just plug and play, then I believe you, but I just don't see how you get around the wiring differences. Anyone care to explain?
http://shbox.com/1/harness_connector_faces.htm
Old Feb 4, 2011 | 07:11 AM
  #43
SS RRR's Avatar
Village Troll
I am not even sure what that connector is for or why it has been brought up. Is there a write up on shobox's page stating a rewire is necessary for the conversion?
I'm telling you, there is no rewiring necessary. This has been done many many times over the years. Do a search on cz28.com regarding "OBDI Conversion" and you'll get threads dating back to 2003. I linked a thread from Ion himself as to what was necessary...
Old Feb 4, 2011 | 01:07 PM
  #44
ks my ss's Avatar
I am running an OBD I conversion from Ion. He puts a resistor in the pcm and all you do is plug in the computer. Nothing else. Did this years ago and has worked perfect ever since.
I think I was actually among the fisrt handfull he did actually.
Old Feb 4, 2011 | 04:50 PM
  #45
1961ba427's Avatar
I took the original obd2 pcm out of my 97 SS M6, removed the original knock sensor, and installed a replacement knock sensor from autozone for a 95 & earlier lt1 (different resistance values) then installed a stock 95 Trans Am M6 pcm that I had laying around from a car I parted out years ago. It works fine. I didn't re-wire or change anything else. I did have a friend "tune" the "new" 95 pcm for my 4.10 gears to correct the speedo. Everything else is the same. CES light stays on due to !egr. lol If I can get my friend slowed down I'll get that corrected as well.
Old Feb 4, 2011 | 05:02 PM
  #46
Rob's Avatar
Rob
Yep, as I said all along, mine was done back in '98. I got mine from Mike Licht of Modern Muscle Car. Of course MMC is long gone but Mike is still around. He was selling them at Memphis 97, so I know he was doing it at least since then.
