parts needed to finish
Old Aug 29, 2013 | 12:49 PM
  #221
am_muscl's Avatar
That's what I was thinking just to get it started and then go from there. Looking to still get the conversion kit and some LS coil brackets from EFI. It's all the little things that are adding up (trans cooler, brakes, gaskets, fluids, spark plugs, abs delete kit)
I still need a link to get the head gaskets. I'm not sure which ones to get as I want to keep the compression up around 11-11.5:1 or higher just so I can run nitrous if I want
Old Aug 29, 2013 | 08:55 PM
  #222
am_muscl's Avatar
Looking at these for head gaskets:
http://m.summitracing.com/parts/mrg-3140g
http://m.summitracing.com/parts/tfs-30494040-040
http://m.summitracing.com/parts/cgt-c5645-040
Pistons are .040 so I'm assuming those are the ones I need. I just don't know which ones to get. I would think the thickest of all?
Old Aug 29, 2013 | 09:16 PM
  #223
1961ba427's Avatar
I run the .028" from Victor Reinz. They are available several places and they are very reasonable at less than $30 each. A visual compared to a GM Impala .026" gasket which is now discontinued....they looked identical. They even measured the same thickness (before use). I haven't heard of anyone having problems with them being stuck to the packaging like the Mr. Gasket ones.
Old Aug 29, 2013 | 09:43 PM
  #224
merim123's Avatar
felpro 1074s are 30/each I think. Isn't the Reinz setup 30 for both?
Old Aug 29, 2013 | 10:14 PM
  #225
am_muscl's Avatar
Does it matter about having 40 over pistons?
Old Aug 31, 2013 | 01:44 AM
  #226
am_muscl's Avatar
How about these? Just to be sure they'll work with the bore?
http://www.jegs.com/i/Mr.+Gasket/720/5716G/10002/-1
Old Aug 31, 2013 | 12:19 PM
  #227
am_muscl's Avatar
Engine bay...
Slowly but surely, the shell should be all done by tomorrow afternoon. Then ill be moving on to the trunk, lt1 ss spoiler, and the Berger panel. Also just picked up some Jegs fender covers so when I'm working on it I don't ruin the fenders. $10 a piece with free shipping, can't beat that
Old Sep 4, 2013 | 12:28 PM
  #228
robsquikz28's Avatar
black always looks better
Old Sep 4, 2013 | 05:24 PM
  #229
am_muscl's Avatar
I'm picking up the shell probably tomorrow. The ebony and ivory look really does it for me. But it's gonna be arctic white again so should be nice n bright.
Old Sep 7, 2013 | 07:27 PM
  #230
am_muscl's Avatar
so now I think I need an electric waterpump. I wanted to get the housing re-powder coated so I tried taking it apart and this is what I got.....
I'm assuming it can't be put back together
Old Sep 21, 2013 | 06:45 PM
  #231
am_muscl's Avatar
So I was able to pull some magic and put the waterpump back together. Hopefully it should work when it's all together.
Also picked these up yesterday from the machine shop.
Some re-worked LE1 heads more now like LE2's. With some brand new Brian Tooley ltx valve springs, and new seals, valve job and surfaced. Machine shop said with the .026 gaskets the CR should be around 10.5-11:1 which should be good for NA and possible nitrous.
Old Sep 21, 2013 | 07:10 PM
  #232
1961ba427's Avatar
Those should be good. I was afraid you had ended up from some aweful junk from the text, but I think they will be fine.
Old Sep 21, 2013 | 09:19 PM
  #233
am_muscl's Avatar
^^^ I wish I had taken before pics. I almost thought they were junk. Shipped with all the spark plugs still in them. All but 2 of the valve stem seals completely ripped. Everything covered in oil, water temp sensor broken off in the head. They looked beat up when I got them but after the good cleaning, I'm satisfied but I may still be looking to upgrade more down the road.
Old Sep 22, 2013 | 07:36 PM
  #234
Badazz 97 TA's Avatar
Damn bud, I cant believe your still doing this project. It feels like its been forever. Its nice to see your still sticking with it though. Nice progress man.
Old Sep 22, 2013 | 09:13 PM
  #235
am_muscl's Avatar
Hahaha thanks joe. Yea legitimately it's been about a 5 year project. I think by the end of this year it should be going down the track.
Old Sep 22, 2013 | 09:57 PM
  #236
ascastil's Avatar
Id like to see this car sometime.
Old Sep 23, 2013 | 10:34 AM
  #237
am_muscl's Avatar
I'm in Gilbert near Val Vista and Ray. Pm me with your contact info if you wanna stop by. I'll warn you it's a giant cluster f*ck of stuff in the garage.
Old Nov 5, 2013 | 06:33 PM
  #238
am_muscl's Avatar
Got some bling today!!!! They look awesome
I've got the best woman in the world. She's agreed to take out a loan on her 401k to help me get this done. So within the next 2 weeks I should have my shortblock, 24x conversion kit, coil brackets, fuel pump, brake lines, and hopefully the interior harness back from BP Automotive.
Old Nov 13, 2013 | 03:57 PM
  #239
am_muscl's Avatar
Ordered new ARP intake manifold bolts, racetronix fuel pump kit, derale trans cooler with a fan, stainless brake lines, and the SJM abs delete kit with a line lock. By Monday I'll order the 24x conversion kit and brackets. Then going through Rockauto to get a knock sensor and a front strut mount, after that I'll be all over BP Automotive to finish my interior wiring harness. Then Dec. 1st the rest of the car gets painted. I will be taking more pics as I start to receive parts and start putting stuff together.
Old Nov 16, 2013 | 01:51 PM
  #240
am_muscl's Avatar
More goodies...
Conversion kit and brackets are ordered, drilled and slotted rotors with pads.
So by the end of next month the paint will all be finished and hopefully by Xmas time I should have a video of it running as long as my dumbass doesn't screw something up
