Help!!!
The heads are identical and can go left or right.
The ports for the coolant crossover must be on the rear. Also the Drivers side head will have a threaded port for the coolant temp sensor...
If you can’t give accurate advise, don’t.
The heads are identical.
Both ends of the heads have steam ports. There’s a plug in one end which would end up at the front.
Both heads have a temp sensor port, there’s a plug in the port on the right head.
Fact remains as they set in front of him they will only work one way.
I can take pictures if you like my heads are sitting right on the bench
If the plugs weren't in the heads you couldn't tell the difference between the two. With the plugs installed in FACTORY configuration, they can only go on one way.
Both heads in the above picture are facing frontwards. You can see the plug that taps into a waterjacket in the pass. side head.
