M6 swap. couple ?'s
my main questions right now involve to wiring.
-would it be easier/faster to swap the interior harnesses or simply modify them with the correct pigtails? i can wire pretty well so i'm not worried about that, and if i have to pull the carpet or dash to swap the harnesses i'd rather just modify the existing one with the pigtails to keep labor and time down. if modifying the harness is easier, where can i get the specific connectors?
-what other parts of the wiring harness need to be swapped? i assume the t56 has some sort of transmission side wiring extension that includes everything for it. should i swap both entire engine bay harnesses while the motors are out?
-do i need to swap in the m6 pcm or would doing it make the swap easier? i've seen some mention of re-pinning parts of it. i don't see why i would do this if i have an m6 pcm sitting there. just need some clarification
-if i do swap pcm's, i will have to sort out the VATS issue correct? if so would it be faster to bypass it or just swap the steering columns/ignition cylinders?
just trying to make sure i have all of this ready to go before i get started. i want to avoid as many hang-ups as possible
-I just modified the stock wiring harness. (very simple since the main wires are already there, they just need to be rewired into the manual transmission pigtails)
-I bought a few transmission pigtails from gm since i didnt have any from a donor car like you will.
-I had to get a chip burned to correct my speedo since i have a 1993.
- the carpet doesn't need to be removed.
-installing the pedals is a pain in the ***
-install the bellhousing then install the transmission.
-i didnt have to re-pin anything
-the wires that need to be modified are under the car.
this is the ultimate write-up...i printed it out and used it when doing my swap
http://www.afrashteh.com/tranny_pics/T56.htm
i finally found the wires i have to connect to the clutch switch, wish the write-up would have said they were on the old a4 shifter harness instead of under the dash. posting that so if someone else needs to search, here it is
so my question is with the reverse light wiring. with having the m6 engine harness and trans connectors, do i still need to connect the a4 wires for the reverse lights or will it be fine to just leave the m6 connections on? i'll be using the m6 pcm
