Weight of LT-5
Old Feb 13, 2004 | 03:58 PM
jmicaelk's Avatar
Default Weight of LT-5
Hi is there any one that knows tha weight of the LT-5 and how many HP it can handle with some mods and also how high rpms it could handle.
Thanks Micael
Old Feb 13, 2004 | 08:27 PM
Fulton 1's Avatar
To be honest have I've never seen any published numbers on the exact weight of a complete LT5. I do know that its a pretty heavy sucker - I've heard anywhere from 100-200lbs more than an LT1. Its definitely a big engine.
There are rumors of a 1000 fwhp LT5 out there - probably a TT setup or running lots of nitrous. They are a strong engine and should be able to handle a goodly amount of power even with the stock crank. As I recall the stroker cranks were prone to crank walk early on. Not sure if this is still a problem.
You might also try www.zr1.net. There are several LT5 experts there that should be able to help you out.
Check out Fastlane Goldstein's site for some potential: http://www.fastlane-racing.com/performa.htm
