octane rating
Old Feb 21, 2011 | 08:45 AM
BigD383lt1's Avatar
it is somewhere between 8.5 to 9.1:1 I wasn't the original builder of the motor so I am not exactly sure... I don't know if he decked the block or not. When you say how hot are you referring to the plug or the actual thermostat?
Old Feb 21, 2011 | 08:52 AM
quik95lt1's Avatar
yea the thermostat what temp is it running at??
and at 8.5-9 :1 i dont se an issue at all running 87 in it......
Old Feb 21, 2011 | 08:57 AM
BigD383lt1's Avatar
I am still having problems with temp... right now it runs hot. I have a 160° thermostat with a 50/50 mix and a full bottle of water wetter and I am still running around 240° when the guy tuned it he said he set the fans to come on at 180° I am still trying to connect to see what the computer shows.
Old Feb 21, 2011 | 09:20 AM
quik95lt1's Avatar
woah!!!! yea thats not good.....something is wrong there I wouldn't run it like that thats WAYYYY to hot....
is the thermostat opening completely???
but running correctly down under 200 i cant see an issue with running 87 at your level...
Old Feb 21, 2011 | 09:55 AM
BigD383lt1's Avatar
yeah the stat is fine it is the third one I've tried.
Old Feb 21, 2011 | 09:56 AM
quik95lt1's Avatar
clogged radiator or something??? gotta figure out that issue asap.......maybe even the water pump is on its way out.....
Old Feb 21, 2011 | 12:43 PM
BigD383lt1's Avatar
new water pump as well. I need to pull the radiator and see what going on!
